Inventor General
Distinguished Contributor
Message 1 of 8 (712 Views)
Assemblies and drawings not updating
712 Views, 7 Replies
01-09-2013 02:49 PM
I've searched all over google and this forum for a solution to this problem and can't find one.
My issue is that whenever I edit a sub-assembly or a part within an assembly, whether it's from within the assembly by right clicking and choosing "edit" or by opening the sub-assembly/part and editing it separetely, once I return to the top assembly, it does not update constraints to reflect the changes. Say I constrain the top of a part to be flush with something in the assembly. Then I edit the part and make it shorter. Once I return to the assembly, the part has shortened but it is no longer flush as it was meant to be. It is lower with respect to the plane it should be flush to. If I double-click the "flush" constraint and then click the check mark, it's like it reminds Inventor the constraint is there and the part hops up where it should be.
Is there any way I can click an "update" button or something so Inventor automatically checks for part changes and re-constrains everything after I make changes to sub-assemblies or parts? I found a "Refresh" button and added it to my Quick Access Toolbar, but it does absolutely nothing.
I often have the same issue with sheets in my .idw files; they do not update once I edit a .ipn or another view in the sheet. Is there a similar solution for this instance as well?
Thanks for any help you can provide.
Message 2 of 8 (703 Views)
Re: Assemblies and drawings not updating
01-09-2013 03:22 PM in reply to: DRoam
Should do it by itself but try Manage -> Rebuild All.
LT.Rusty
Message 3 of 8 (701 Views)
01-09-2013 03:23 PM in reply to: DRoam
Try hitting rebuild all and / or update.
___________________________________________________________
Product Design Suite Ultimate 2013, 2014
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / 2xRadeonHD 4870 in CrossfireX
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
Curtis_Waguespack
Message 4 of 8 (700 Views)
01-09-2013 03:25 PM in reply to: DRoam
Hi DRoam,
A couple of things come to mind.
Do you have a lot of adaptive parts in the assembly?
Also check this setting:
Tools tab > Application Options > Assembly tab > Defer Update option (turn this off if it's on)
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 5 of 8 (665 Views)
01-10-2013 10:40 AM in reply to: RobJV
I haven't been able to test it because the issue hasn't re-occured yet, but it appears this will work, thanks!
Message 6 of 8 (662 Views)
01-10-2013 10:44 AM in reply to: DRoam
Thanks all for the replies. @Curtis, I don't have very many adaptive parts in the assembly. Just many, many constraints. Also that option was turned off, thanks for the info though.
Message 7 of 8 (416 Views)
07-03-2013 12:56 PM in reply to: DRoam
Hello! Try this, it seemed to work.
On the drawing view rt click>edit view>level of detail> toggle this a couple times. This seemd to make the permanent model browser lightning bolts go away.
"If wishes were horses,
we'd all be eating steak!"
Active Contributor
Message 8 of 8 (353 Views)
08-21-2013 02:34 PM in reply to: DRoam
I am having the same problems with my drawings.  I create the view from an ipn and it does not update any changes that I have made in the presentation.  I've tried updating the drawing by clickimg on the Update button and it still does not update. This is not isolated to just one drawing, it will happen intermittently.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
