Inventor General
Active Member
cheree.lee
Message 11 of 16 (152 Views)
Re: Assemble - grip snap
11-20-2012 03:42 PM in reply to: cheree.lee
As I said, this is a collection of previously used part being put to a new task.  The come from some files that were metric and others that were english, different designers, different eras, and suppliers who are notorious for goofy dimensioning.
Stir in my newness to Inventor and frustration prevails.
JDMather
Message 12 of 16 (150 Views)
11-20-2012 03:45 PM in reply to: cheree.lee
This is typical for what I see all the time.  If you let it frustrate you - you will soon not have any hair and/or a hole in the wall from beating your head...  :smileytongue:
At least the sketches are dimensioned/constrained with some logical order of creation - so it is easy to track down the problem.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
cheree.lee
Message 13 of 16 (143 Views)
11-20-2012 03:52 PM in reply to: JDMather
Back to my one question............was I correct in thinking that the same steps that sudccessfully got the first bolt in place and constrained should have worked for all of them?  If the bolt patterns was the same.
Also, most of the parts I simply pulled in from the other sources.  I didn't  clean them up, or do anything more than take a first wack at duplicating the old existing drawings.  I am thinking I should do that now before I go too much farther.   Your thoughts?
JDMather
Message 14 of 16 (140 Views)
11-20-2012 03:56 PM in reply to: cheree.lee
Same technique should work for all of them.
I think you will find that most people don't trust Acad work once they start using Inventor, especially if the work was done by someone else.  At least with Inventor you have a history tree you can check to see how something was done and where they went wrong.  Without a history I always feel like I need to start over from scratch because I can't trust anything someone else did if I find one thing wrong.
Active Member
cheree.lee
Message 15 of 16 (135 Views)
11-20-2012 04:03 PM in reply to: JDMather
I was beginning to feel that way on a lot of the work I've been doing in Inventor.  I've already given up trying to bring really old AutoCAD files in.
Part of me wanted to believe that I could just pull them in an go merrily down the path.  The I stared running into things like dimension over rides.
Thanks for your help.  I'm going to spend some time cleaning up the mess, and then working with getting the patterns corrected.
If I run into trouble I'll be back in the forum.
One last question though, if my holes have chamfers and lead chamfers does that mess with the bolt connections?  should I be picking the edge of the chamfer or the edge of the hole itself?
JDMather
Message 16 of 16 (133 Views)
11-20-2012 04:08 PM in reply to: cheree.lee
No problem with chamfers.
Select the clamping face circle. (which I assume would be your chamfer edge rather than hole edge)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
