Inventor Forum
Arrays on curved faces!
5 REPLIES 5
130 Views, 5 Replies
Is it possible to clone a number of parts on a curved face?
Like 5 curved windows distributed like parts! in an assembly on a curved
wall that is following a path.
5 REPLIES 5
Like pillows on a curved sofa.
You could use the pattern component tool. This will work on a constant
radius curve. If you're talking about a variable radius curve, you will
probably have to place and constrain each part .
Hal Gwin
Mechanical Designer
Xenogen
If you can manage to do it withing the confines of a single ipt., then you
can array along a path.
"Hal Gwin" wrote in message
news:FB8EB634D7E9E590CD736119DB1FB930@in.WebX.maYIadrTaRb...
> Hal Gwin
> Mechanical Designer
> Xenogen
Thanks for the responds!
A path array would work!
Is it good design to create "larger" arrays within parts ?
Depends on the design and the likelihood of major changes. I have a couple
of parts that have only had minor edits and no problems, I also have a few
that were rebuilt completely because of major edits and major problems.
Hal Gwin
Mechanical Designer
Xenogen
