Hello I am a student who is currently using Autodesk Inventor Proffesional 2014 version. I was thinking of installing the 2015 version , as the 2014 version does not work with the windows 8.1 so I am stuck on windows 8. I wanted to know would the files on 2014 work on 2015 and vice versa.
Solved by JDMather. Go to Solution.
Solved by cbenner. Go to Solution.
Welcome.
Files created in 2014 will open in 2015, but once they are saved there is no going back to 2014 or earlier.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
@Aortax wrote:
..., as the 2014 version does not work with the windows 8.1 ...
Install Inventor Service Pack1 and Update3.
