Inventor Forum
Arc,s extruding with weird results...
3 REPLIES 3
293 Views, 3 Replies
Ive just installed Inventor Pro 2015 on a Mac-Book Pro (in a windows 7 32bit environment) 2.2ghz i7, 8gb, Intel HD3000 graphics.
I am going through the tutorials and have run into a quirk.
Tutorial is entitled "navigate the sketch environment"
When I try to extrude any sketch with curves in it it goes crazy, see screenshot...
I have tried with circles with no dimensions, same result. Rectangles, Polygons extrude well.
Any ideas, autocad has no issues on my system normally.
3 REPLIES 3
johnsonshiue
Hi! It seems like a graphics issue. Could you try changing the following setting and see if it helps?
Go to Tools -> Application Options -> Hardware -> Conservative mode -> OK.
Restart Inventor.
Thanks!
Software Test Engineer
in reply to: johnsonshiue
Thanks that got it.
Now to find the tutorial again...
JDMather
Look here.
