Inventor Forum
Arbitrary hatch angles on a repeated pattern of parts.
3 REPLIES 3
jyager
343 Views, 3 Replies
I have a louver with 7 blades, pattern starts from the bottom up...this view from the top down better shows the discrepancy however.
You can see, it seems like every other blade is hatched in a different direction...ideally the 2nd one down is what I'd like to see...but even blades 1 and 3...while differing from 2 and 4, don't seem to share the same odd angle?
See attached.
Jason Yager
Inventor Professional 2023.2
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
3 REPLIES 3
jyager
in reply to: jyager
The blades are an .ipt patterned in a .iam.
Jason Yager
Windows 10 Pro 21H2
32GB RAM
PaulMunford
in reply to: jyager
Hatching in Inventor is a bit of a PITA if you don't like the automated hatch.
In this case you need to pick each individual one to align it to your requirements.
You should be able to select them all and operate on them together - or use a 'Match properties' type command to match em all up ~sigh~
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
PaulMunford
in reply to: PaulMunford
Update - this post might help:
https://forums.autodesk.com/t5/inventor-forum/understanding-inventor-hatch-angles/m-p/7754352#M68087...
