This unicon.exe file contains the
unicon.reg file, which resolves an error message that may be displayed if
you are running an AutoCAD® 2004-based product on the Windows NT® 4.0 operating
system.
An error message similar to the following may be
displayed when you close any open application:
APPLICATION ERROR: The instruction at
"0x70a04f2f" referenced memory at "0x01210ec0". The memory could not be "read".
Click on OK to terminate the application.
The problem may affect the following AutoCAD
2004-based products if they are installed on the Windows NT 4.0 operating
system:
style="MARGIN: 0in 0in 5pt 0.3in; TEXT-INDENT: -0.25in; mso-margin-top-alt: auto; mso-list: l1 level1 lfo1; tab-stops: list .5in">
style="FONT-SIZE: 10pt; FONT-FAMILY: Symbol; mso-bidi-font-family: Arial">·
style="FONT: 7pt 'Times New Roman'">
AutoCAD® 2004
AutoCAD LT® 2004
Autodesk®
Architectural Desktop 2004
Autodesk Map
2004
Autodesk® Land
Desktop 2004
Autodesk®
Mechanical Desktop® 2004
AutoCAD®
Mechanical 2004
Before you install the unicon.reg file, you
should back up the HKEY_CLASSES_ROOT registry hive. If you do not know
how to back up this hive, contact your system administrator.
To install the unicon.reg
file
style="MARGIN: 0in 0in 5pt 0.3in; TEXT-INDENT: -0.25in; mso-margin-top-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list .5in">
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">1.
Download the
unicon.exe file to a location on your hard drive.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">2.
Double-click the
unicon.exe file, and then extract unicon.reg. Make note of the
location where you extracted the file.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">3.
Close all open
applications.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">4.
Open Microsoft®
Windows Explorer and navigate to the unicon.reg file. Double-click
unicon.reg.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">5.
The Register
Editor message is displayed, confirming that you successfully entered
unicon.reg into the registry. Click OK.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">6.
Close Windows
Explorer. The Application Error message is displayed one last time.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">7.
Click OK in the
Application Error message to close it.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">8.
Restart your
computer.
