Inventor Forum
Aplication Error....memory could not be written.
3 REPLIES 3
257 Views, 3 Replies
I am getting this error a few times a day.
"The instruction at "0x0f113073" referenced memory at "0x7f50ae88". The memory could not be "written"
Click on OK to terminate the program"
And gone is everything. I am running a P4, 2GHz Intel,
1024memory,page file 4670mb,xp professional 5.1 build 2600, Nvidia TI4400 128mb
Any, ideas?
3 REPLIES 3
I get it too.
Tom
The first thing I would do is try the memory tester that Cy posted about in this forum a while ago. Do a search and you will find it. It has helped me out in the past.
i was getting that message right and left. i
haven't seen it since i applied all the patches to mdt2004. i think you'll want
the unicon_reg fix. i have pasted the readme file contents so you could read
it...
face=Arial>Unicon_reg File: Application Error Message
Solution
This unicon.exe file contains the
unicon.reg file, which resolves an error message that may be displayed if
you are running an AutoCAD® 2004-based product on the Windows NT® 4.0 operating
system.
Description of
Problem
An error message similar to the following may be
displayed when you close any open application:
APPLICATION ERROR: The instruction at
"0x70a04f2f" referenced memory at "0x01210ec0". The memory could not be "read".
Click on OK to terminate the application.
Affected Products
The problem may affect the following AutoCAD
2004-based products if they are installed on the Windows NT 4.0 operating
system:
style="MARGIN: 0in 0in 5pt 0.3in; TEXT-INDENT: -0.25in; mso-margin-top-alt: auto; mso-list: l1 level1 lfo1; tab-stops: list .5in">
style="FONT-SIZE: 10pt; FONT-FAMILY: Symbol; mso-bidi-font-family: Arial">·
style="FONT: 7pt 'Times New Roman'">
AutoCAD® 2004
AutoCAD LT® 2004
Autodesk®
Architectural Desktop 2004
Autodesk Map™
2004
Autodesk® Land
Desktop 2004
Autodesk®
Mechanical Desktop® 2004
AutoCAD®
Mechanical 2004
Installation
Instructions
Before you install the unicon.reg file, you
should back up the HKEY_CLASSES_ROOT registry hive. If you do not know
how to back up this hive, contact your system administrator.
To install the unicon.reg
file
style="MARGIN: 0in 0in 5pt 0.3in; TEXT-INDENT: -0.25in; mso-margin-top-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list .5in">
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">1.
Download the
unicon.exe file to a location on your hard drive.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">2.
Double-click the
unicon.exe file, and then extract unicon.reg. Make note of the
location where you extracted the file.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">3.
Close all open
applications.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">4.
Open Microsoft®
Windows Explorer and navigate to the unicon.reg file. Double-click
unicon.reg.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">5.
The Register
Editor message is displayed, confirming that you successfully entered
unicon.reg into the registry. Click OK.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">6.
Close Windows
Explorer. The Application Error message is displayed one last time.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">7.
Click OK in the
Application Error message to close it.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">8.
Restart your
computer.
