When I did my migration, there were a couple large files which seemed to
take an inordinate amount of time. Is this what you're up against? Has
the migration failed with this error message? Or did you try to stop
and do some other work and recieved this message?
tdrawdy wrote:
> Has anyone seen this?
> This action cannot be completed because the other application is busy.
> Choose "switch to" to activate the busy application and correct the
> problem.
> I opened windows task manager and no other program is running. The CPU
> is pegged at 100% under performance, and I have an Inventor.exe running
> at the bottom of the processes tab that is using 99% of the CPU.
> Furthermore, I have migrated 963 out of 991 files.
> Should I stop the program from the task manager as I cannot stop the
> program from the migration utility? What consequences will I face? Can
> you help a confused man out?
> Thanks,
> Tom Drawdy
> Design Engineer
> SupremeMetal Inc.
