So at my company we have thousands of drawigs. Whenever we are working on one or finish one we go to iproperties>status>design state and select either work in progress, pending, or released. Basically pending means its done but has not been checked by a superior. The problem is we have about 1000 drawings pending. We use the vault to access all our drawings and it seems the only field you can't add to the custimized bar is "Design State". Literaly every other option is there but this. I want to be able to organize or search for drawings that are just pending or works in progress or released. Going through 8000 drawings to find each one is very hard. Any way to do this? Thanks.
I would have posted this in the Vault forums,.. .but since it is here....
You can create a custom property in Vault and map it to Design State in the iproperties, and then add that to your custom view. Or you can actually set the Design State in Vault, and sort based on that.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
