I dont know whats happening, but the last two times I saved and exited Inventor Fusion. When I try to open and continue I get an error, losing my file/work. Tired of re-doing everything , not very efficient. Can someone please help? How do I even work around the 1.5MB file limitation on attachments?
Solved by JDMather. Go to Solution.
It could be your network and security settings not allowing to Write. Try saving to your machine and a local directory.
@Anonymous wrote:I dont know whats happening, but the last two times I saved and exited Inventor Fusion. ...
Autodesk Inventor is not Inventor Fusion.
You might post your question in the Fusion forum.
http://forums.autodesk.com/t5/Inventor-Fusion/bd-p/370
Include information on whether you are using the Mac or the Windows OS version.
I recommend that you search Google on Fusion 360 and click the link to sign up for the Beta.
The file size limit is larger over here http://www.augi.com
If you post over there - be sure to come back here and post url to download.
