Inventor Forum
Another flattening riddle
4 REPLIES 4
zakaronius
274 Views, 4 Replies
I am trying to model a hollow curved disk as we would build it; faces cut form 1/8" material and roll formed and a return of.0625 thickness spanning the two.  The three parts were devived from disk3.ipt.   The faces both flatten.  The return thinks it flattened but did not.  Each of the 3 parts has its sheet metal rules thicknes set to "thickness".  I have learned a bit searching for someone's simalar problem but not solved my own.  I am pretty sure that this will flatten without deformation.
Any insight would be appreciated.
Zak
Tags (1)
4 REPLIES 4
mrattray
in reply to: zakaronius
Inventor can't unfold that.
Mike (not Matt) Rattray
zakaronius
Thanks for the quick response.
It seems that Inventor 2013 can not unfold this yet I find that very hard to believe.
Considering Dr Mather's comment regarding part2:
http://forums.autodesk.com/t5/Autodesk-Inventor/How-can-I-flatten-these/m-p/3465526/highlight/true#M...
..MIGHT be able to be flattenned;  clearly part2 has compound curves.  I would have thought it impossible to flatten without deformation.  My return seems to me as it would lay flat as anything.  I guess I'll try something different to prove or disprove that notion.
Thanks.
zakaronius
Yup.  You are right, Mike.  Thanks
zakaronius
Still trying to solve what, seems to me, ought to be a simple problem.
Attached is a new version of the return that would not flatten.  A sweep rather than a patch between two surfaces.
No deleted faces.  Sheet metal environment  Thickness matches SM rule...
I exported this to Rhino where it does flatten yet it still will not in Inv2013.
Any insight?
Thanks in advance...
