Inventor Forum
Animator v3.0 Release Canidate
29 REPLIES 29
Message 1 of 30
821 Views, 29 Replies
Animator v3.0 release candidate is ready for download.
http://www.sdotson.com/vba/animatorv30.zip
Charles Bliss did a LOT of work on this release and should be commended for
his hard work! Thanks Charles!
Charles added the ability to record an AVI directly from the Animator
dialogue and made the program an add-in so that it remains persistent in the
assembly environment giving you one click access to the program. This
version works on R6 only. (To use on Animator on Inventor R5.3 please
download Animator v2.5 from my site).
Be sure to read the User Manual that comes with the zip file.
This is a pre-release. Test it, thrash it, let us know if it breaks. As
we/you find bugs we'll update the code. So far I've had to try REALLY hard
to crash it so hopefully it's pretty bulletproof. As always, make backups
of your assembly. We don't want you screwing up that machine that has to be
built next week.
This version will read v2.5 sequence files so users of v2.5 should be able
to pick up where they left off.
What's New in v3.0
a.. Ability to capture AVI animations directly from the Animator interface
b.. Program is now an add-in and the icon resides on the assembly toolbar
c.. Program request a save if changes to the sequence file have been made
and Animator is closed
d.. Sequence and AVI filenames are defaulted to that of the assembly
Improved error trapping and crash prevention
We hope you find this to be a useful program and welcome any comments,
suggestions and bug reports.
Sean Dotson, PE
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
29 REPLIES 29
Message 21 of 30
Start/Run/ type cmd (will open a command window) or
start/programs/accessories/command prompt
navigate to c:\program files\autodesk\macros (if
that's where you installed it)
type regsvr32 animator.dll  (you put in an
extra "e")
then exit the command window and return to the
c:\program files\autodesk\macros directory
and then double click on animator.reg  say yes
to the next dialogue.
What OS are you running.  Wonder if you and
Todd are having the same problem?
Todd, what about you?
Okay ... I'm lost I guess ... again! When you
say go to the install location, I assume in Explorer. How do you type in a
command window in Explorer. Regserv32 isn't basic DOS command either, I don't
think ... what do you mean? You have a version-for-the-retarded of that
statement?
~Larry
Hmm.. Did you have Inventor closed when you
installed it?
Close Inventor
Try going to the location of the install
(if you used the default it will be c:\program files\autodesk\macros) in a
command window and then type
Reopen Inventor.  See if the add-in is
there.  Check it to make sure it's loaded.
Hope that works...
Sean
Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
Sean,
Can't wait to try this one, but having trouble getting it loaded. I
downloaded the .zip file which included the .pdf and the installer and
followed the directions in the .pdf. No new icon so i went to the add-in
manager and the only thing there was one called "Animator" not
"Animator.clAnimator" like the manual said. Not sure if this is why it's
not loading. The "Animator" add-in won't load it. Any help would be
appreciated, looks like a really cool
program!
Message 22 of 30
W2K
I tried it from Run and command prompt. I
probably had the old "Bad command or file name" error, I'll try it again. Before
Windows, I couldn't understand why my mother didn't just name me: Bad
command or file name!
~Larry
or start/programs/accessories/command prompt
extra "e")
yes to the next dialogue.
don't think ... what do you mean? You have a version-for-the-retarded
of that statement?
~Larry
installed it?
Close Inventor
Hope that works...
Sean
Dotson, PE
Check the
Sean,
program!
Message 23 of 30
Okay ... it worked this time ... guess being
lisdexia was indeed the problem.
I don't think there is a platform problem, I
think we both just tried to load the add-in with Inventor open. Maybe
a:
Warning For Dummies
Inventor must be closed to load this add-in;
Dufas!
Thanks Sean! I'm gon'a play with that when I get
time.
~Larry
statement?
~Larry
installed it?
Close Inventor
Hope that works...
Sean
Dotson, PE
Check the
Sean,
program!
Message 24 of 30
"Maybe a:
Warning For Dummies
Dufas!"
I think it's in the help file
<g>
guess being lisdexia was indeed the problem.
face=Verdana size=2>
Warning For Dummies
Dufas!
get time.
~Larry
of that statement?
~Larry
installed it?
Close Inventor
Hope that works...
Sean
Dotson, PE
Check the
Sean,
program!
Message 25 of 30
Todd_G
Win2K here too. I definitely had IV closed when I tried to install it, just had that problem registering the .dll. I do have admin rights on my machine so that must not be it. But i'm a dummy AND a dufas so who knows what I did LOL
Message 26 of 30
Sean FYI I also had to add the install manually as you described.
WIN2k Full administrator rights.
Thanks for the great program!!
Brian
"Sean Dotson" wrote in message
news:10BFBAF28A9F4633303C50BC908F1B4F@in.WebX.maYIadrTaRb...
> To use it Larry you have to have true desire. You can't just use Animator
> you have to BE the Animator!
> (What???)
> oops!
> Sean Dotson, PE
> "Larry Caldwell" wrote in message
> news:4C173EB0A30EB0DF1D98111FC0CAFE69@in.WebX.maYIadrTaRb...
> > Pdf: "...If you are using R5.3 and want to be Animator please
download
> > v2.5 from..."
> > Be all that you can be, I guess!
> > ~Larry
> > news:E0B5EB64DF7716C19E3E408833B81B49@in.WebX.maYIadrTaRb...
commended
> > for
in
> > the
> As
> > hard
> backups
> to
> > be
> > > built next week.
> able
> > > What's New in v3.0
> > interface
> > toolbar
> > made
> > > Sean Dotson, PE
Message 27 of 30
Thanks Brian. I think I'll need to add something about this to the
documentation.
Sean Dotson, PE
"Brian Corbin" wrote in message
news:297289F91C77EC6C241253829447B3D7@in.WebX.maYIadrTaRb...
> Brian
Animator
> > (What???)
> > oops!
> > Sean Dotson, PE
> download
> > > v2.5 from..."
> > > ~Larry
> commended
> > > for
Animator
persistent
> in
> > > the
This
please
breaks.
> > As
REALLY
> > > hard
> > backups
has
> > to
> > > be
> > > > built next week.
be
> > able
> > > > What's New in v3.0
> > > interface
> > > toolbar
been
> > > made
assembly
comments,
> > > > Sean Dotson, PE
Message 28 of 30
I would like to better understand what didn't happen. When the
AnimatorInst.exe program runs, it is supposed to end by running
InsAni.bat. Contained in the bat file is a call to regsvr32 and to
regedit.
Is is somehow possible that you were installing from a drive which
Windows didn't think was mapped? It is an assumption that the bat file
is in the same directory as the dll and that it is running from a mapped
drive. UNC's don't work very well with bat files.
>Brian
>>(What???)
>>oops!
>>Sean Dotson, PE
>download
>>>v2.5 from..."
>>>~Larry
>commended
>>>for
>in
>>>the
>>As
>>>hard
>>backups
>>to
>>>be
>>>>built next week.
>>able
>>>>What's New in v3.0
>>>interface
>>>toolbar
>>>made
>>>>Sean Dotson, PE
Message 29 of 30
Charles,
I have a local C,d,e drive. I unzipped the files to e:\temp and run the
installation.exe file. I selected the default directiry c:\program
files\autodesk\macros and the screen flashed and was done. I then run INV 6
SP1 and there was no icon. So I looked in addins but animator was not there.
After shutting down INV and following seans manuall install instructions it
worked fine..
Hope this helps
Brian
"Charles Bliss" wrote in message
news:3DF50640.9060700@cbliss.com...
> regedit.
> >Brian
Animator
> >>(What???)
> >>oops!
> >>Sean Dotson, PE
> >download
> >>>v2.5 from..."
> >>>~Larry
> >commended
> >>>for
> >in
> >>>the
> >>As
> >>>hard
> >>backups
> >>to
> >>>be
> >>>>built next week.
> >>able
> >>>>What's New in v3.0
> >>>interface
> >>>toolbar
> >>>made
> >>>>Sean Dotson, PE
Message 30 of 30
Charles,
First of all, this is a fantastic program. Great work all of you guys.
I have IV6 installed in drive 😧 and the icon did not show after the
installation,
and its was not visible in the Tools/Add-Ins area either.
I manually run the InsAni.bat and that did it.
In order to understand how the program works I downloaded slideexample.zip
and have been getting a feel for the program. Awesome!
Erich
> regedit.
