Inventor General
New Member
Bonuman
Message 1 of 4 (284 Views)
Animated chain
284 Views, 3 Replies
01-25-2014 12:15 PM
After a period of 'googling'... frequently ending up here, at this forum, finding a lot of usefull information, the time has come to create an acount and participate :smileyhappy:
I'm trying to create an animated chain (Inventor pro 2012), therefor i set up a master sketch with a (driven) feature pattern of workplanes. The workplanes are constrained as 'normal to curve' (the curve is the path of chain, like a 'slot-hole'). Attached the image... As you can see the workplanes correctly rotate in the arcs of the sketch, thats normal to curve, so far so good...
The next step should be placing the Master in an assembly and place one chainlink. I constraint the chainlink to the first workplane/feature of the master. After that i pattern the component (chainlink) according to the feature pattern. Here is the problem... I would expect the chainlinks to rotate at the arc-parts, so that their XZ-plane mates the patterned workplane, but this isn't happening. The patterned components stay in the same orientation as the first component...
What goes wrong? I can't figure out...
grz. Arjan
nb. I first do the outer chainlinks...
JDMather
Message 2 of 4 (279 Views)
Re: Animated chain
01-25-2014 12:46 PM in reply to: Bonuman
See image. Edit your Master file pattern.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
Bonuman
Message 3 of 4 (218 Views)
Re: Animated chain
01-27-2014 08:54 AM in reply to: JDMather
Thanks a lot JDMather, it worked!
I did not try the Direction2 buttons, thought it wouldn't matter...But it does :smileyhappy: eventhough I don't really understand why...
grz.
arjan
JDMather
Message 4 of 4 (206 Views)
Re: Animated chain
01-27-2014 09:23 AM in reply to: Bonuman
The dialog box is misleading - that is not Direction 2 even though it appears under Direction 2 when expanding the dialog box.
It is Orientation for Direction 1  (notice there is grayed out orientation for Direction 2, but since Direction 2 is not used in this example...).
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
