I am working on a project involving a wedge. It is common to describe the slope of this wedge as a % (rise/run) rather than in degrees. A four degree slope is something like a 5.7" rise in 100" of run.
Is there a way to change an IDW dimension style to measure the angle in % grade?
I have been drawing a "helper" triangle on my idw showing a 100" horizontal run and the matching rise, but that is not as nice as a dimension that says 20% grade or whatever.
Steve Walton
Solved by swalton. Go to Solution.
I just created a user parameter in the wedge ipt, formatted it, and marked it for export. I can use a leader and display the custom iprop. See attached png.
Steve Walton
