I am jammed in this matter...I have my 3d sketch and i would like to control the angle betewwen the two planes with
the dimension of the 3d sketch. I am at the level that i can change angle between planes.
Any input will be great.
Dan
Hi!!
You have to make dependent the plane position instead the 3D line dimension.
See the files attached, i think that's what you search.
You can open the variables table and change the 3D line dimension... press enter and you see in time the resultant angle.
Regards.
