Ahh, but once again the "line" needs to be connected to the outer projected
edges.... a PITA if the tube has rounded edges.
It would be faster than trying to get a sketched "triangle" to close,
though.
QBZ
"Brian Corbin" wrote in message
news:646FD8586EE99C0817BCC0E9875B1863@in.WebX.maYIadrTaRb...
> Could sketch a line at 45deg then use split part...
> "Quinn Zander" wrote in message
> news:5E490619E5715E6C75F79CB4FF7C71E0@in.WebX.maYIadrTaRb...
> > If the tube has rounded edges, the actual outer edges won't project and
it
> > becomes a hassle at times to force everything to project and select to a
> > contiguous selectable area for the extrude.
> > Another method is to create a sketch on the end of the tube and revolve
a
> > stretched rectangle to achieve the miter.
> > Of course, adaptively extruding to an adaptively place workplane is the
> best
> > way 😉
> > QBZ
> > "Gaets" wrote in message
> > news:0465039EADFBAE59D9AA9D29B18BD9B7@in.WebX.maYIadrTaRb...
> > > Use a side as your sketch plane, project edges, draw line from corner
at
> > 45
> > > deg.
> > > extrude, cut.
> > > Gaets
> > > "Bob Johnson" wrote in message
> > > news:9B8A9D6FA318C6C4488ABE7BEE7FCBC6@in.WebX.maYIadrTaRb...
> > > > How do I make an angle cut on the end of a square tube? I have
already
> > > > modeled the tube and want to place a 45 degree bevel on the end. The
> > tube
> > > is
> > > > 1.25"X2.00"X 24" long, with a .10 wall thickness.
> > > > Thanks, Bob
