Inventor Forum
Angle Measurement
18 REPLIES 18
Message 1 of 19
739 Views, 18 Replies
Angle Measurement
I have a part with 2 faces that measure 90 deg in the part file, and in an
assembly file they measure slightly more see below. This is a big problem.
Cory McConnell
BJ pipeline Inspection
18 REPLIES 18
Message 2 of 19
How will you measure the 90.0000000000013 angle in real life to see if it is
actually 90.0000000000013 and not 90.0000000000000?
Stephen R.
"Cory McConnell" wrote in message
news:70FEF14CC118CA6B5BA0497DD2D4635F@in.WebX.maYIadrTaRb...
problem.
> Cory McConnell
Message 3 of 19
I have made a part in the context of the assembly, based on those 2 faces
assuming they are 90 deg. Certain extrusions in this part leave remnants
because the angles between the plains are not 90 deg in the assembly, even
though they are drawn that way in the part.
Cory McConnell
Message 4 of 19
I see your point and I do agree that you most likely modeled everything
perfect. But nothing in this world is exactly 90 degrees. You have to
decide what is an acceptable approximation to 90 degrees to have it pass or
fail acceptance criteria. If you were working on the molecular level, I
could see .00000000000013 being a concern. But working on a typical shop
floor using clips for assembly, I don't see .00000000000013 being a concern.
Stephen R.
news:4D9E09924BB64516D1D562730494B2AC@in.WebX.maYIadrTaRb...
> Cory McConnell
Message 5 of 19
I realize all that. The following screen shot shows what happens with my
extrusion when my part is based off those 2 planes....
Cory McConnell
Message 6 of 19
The bigger problem is that your constraints will not work. In my situation
what usually happens is that someone forgets to convert imperial to metric
using IV (which maintaining all the decimals) and instead uses a calculator
(rounding) - a big No-No.
Vadim
"stephen r" wrote in message
news:36197619E28490F4E9440B55FF34BF4D@in.WebX.maYIadrTaRb...
or
concern.
> Stephen R.
faces
remnants
even
> > Cory McConnell
Message 7 of 19
Cory, are you sure the decimal place precision is set to the same in both
files? Maybe they are both the same but one measurement is rounding it off?
Now that I think of it, how are you getting so many decimal places in the
measurement? My setting only allows up to 5 places in the dialog.
problem.
> Cory McConnell
Message 8 of 19
I see this every day. I thought it was just Inventor & no one thought it was
a big deal.
Dave Hoder
Product Design Engineer
idX Seattle
www.idxcorporation.com
Message 9 of 19
Do you have the same number of decimal places selected in both
measurements? I have only seen something similar when using user vs IV
conversion of metrics/imperial as Vadim suggested.
> Cory McConnell
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4403 w/registry update
Dell UltraSharp 19" LCD
Message 10 of 19
The precision is the same in both files. To get that many places, I clicked
the > and picked all decimals.
Cory McConnell
Message 11 of 19
Another thing - I just discovered that it comes up with a different angle
every time I measure in the assembly
Cory McConnell
Message 12 of 19
Click on the arrow in the measurement box, at the bottom select 'All
Decimals'. That will get out to 15 decimal places.
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
Message 13 of 19
Do you get the same measurement if you turn off the visibility of all
the other parts and then measure that part?
> Cory McConnell
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
Message 14 of 19
I deleted everything from the assembly, except for the part I have been
measuring. Doesn't seem to make any difference.
Cory McConnell
Message 15 of 19
Maybe it's depending form the part's
position relative to the assy's origin?
The total precision of the modeller is
"only" about 15 decimals!
Michael Puschner
www.scholle.de
"Cory McConnell" schrieb im Newsbeitrag
news:0EA29FA10F50CDBE86C1FCEEC4FE66CC@in.WebX.maYIadrTaRb...
> Cory McConnell
Message 16 of 19
I think this may be related to the problem I've been seeing with assembly constraints breaking at apparant random moments. This
also happened in MDT 4 and MDT 5 when using the ACADISO template to create parts - dimensions would change their value in the 6th
decimal place at random causing assembly failures.
John Bilton
Message 17 of 19
Can you post the part and assembly to Customer Files? I would like to look
into it.
Loren Jahraus
Autodesk Inventor Workflow Team
> Cory McConnell
Message 18 of 19
Turns out that it is working fine this morning. I will keep an eye on it.
Cory McConnell
Message 19 of 19
Curious thing..... a few years ago I was doing some measurements on a
series of AutoCAD dwgs. I found that the measurements varied slightly
from machine to machine, AMD to Intel and from day to day on the same
system after reboots. Careful investigation led me to the floating point
processor in the CPU as being the probable culprit.
As precise as we want the measurements and software to be, we are
utterly dependent on the hardware and operating systems driving our CAD
software.
Keep in mind that the kernel accuracy in Shape Manager/ACIS is 10-6,
while most other kernels range from 10-2 to 10-3. AutoCAD (2D) is listed
at 10-16.
Dennis
>Cory McConnell
Dennis Jeffrey
Autodesk Product Consulting and Training
Center for Design Excellence
http://www.design-excellence.com
260-459-1311 ext 221 or 800-550-6070 ext 221
