Inventor Forum
Angle Constraint / Drive Constraint Issues
6 REPLIES 6
d3lilley
1524 Views, 6 Replies
Hi everyone,
I am designing a vertical axis wind turbine just for some practice (just started using Inventor) and everything was going smoothly until I tried to "animate" it spinning.  First, I set up a work plane that goes through the center of the structure, and then I clicked angle constraint "explicit reference vector." After watching several youtube videos, I figured that I should click on the work plane, click on another reference point, and then click another point that would be orthogonal to those two (right?). Well after I choose the first point, Inventor will only allow me to choose the center axis  as the second option (which I think should be the third option).
Regardless, no matter what I do it won't work.
Has anyone else experienced this? I attached the file if anyone would like to give it a go.
Cheers
Drew
6 REPLIES 6
JDMather
in reply to: d3lilley
First of all an assembly file without part files is useless.
You should not need to create the workplane - use one of the origin planes.
The CADWhisperer YouTube Channel
d3lilley
in reply to: JDMather
Sorry about that!
It will only allow me to upload three attachments, and the assembly contains 5 different part files. I will post 3 in this post and 2 in the next. Please let me know if there is a better way to do this!
d3lilley
JanVarholik
Inventor complains about the missing files:
VAWT structure.iam
Shaft1.ipt
SKFEE 3ANSI.ipt
locking collar.ipt
when I try to open the attached assembly. Could you create a zip file of all missing components (and upload it), so I could take a look at it?
d3lilley
in reply to: JanVarholik
I did a "pack and go" (love that name)  and then compressed all those files into a zipped folder. Hopefully this will work!
JanVarholik
One of the ways to animate your turbine is creating two workplanes. One by selecting Shaft:1\Origin\XY Plane. This workplane will be attached/constrained to your Shaft:1. Create another one constrained to VAWT structure:1. Since both workplanes will share the same shaft axis, you can easily constrain them by angular constraint. Then you drive the constraint as needed.
