Inventor General
Active Member
Message 1 of 7 (581 Views)
Angle Constraint / Drive Constraint Issues
581 Views, 6 Replies
07-30-2012 05:14 PM
Hi everyone,
I am designing a vertical axis wind turbine just for some practice (just started using Inventor) and everything was going smoothly until I tried to "animate" it spinning.  First, I set up a work plane that goes through the center of the structure, and then I clicked angle constraint "explicit reference vector." After watching several youtube videos, I figured that I should click on the work plane, click on another reference point, and then click another point that would be orthogonal to those two (right?). Well after I choose the first point, Inventor will only allow me to choose the center axis  as the second option (which I think should be the third option).
Regardless, no matter what I do it won't work.
Has anyone else experienced this? I attached the file if anyone would like to give it a go.
Cheers
Drew
Message 2 of 7 (572 Views)
Re: Angle Constraint / Drive Constraint Issues
07-30-2012 06:33 PM in reply to: d3lilley
First of all an assembly file without part files is useless.
You should not need to create the workplane - use one of the origin planes.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Member
Message 3 of 7 (569 Views)
07-30-2012 06:54 PM in reply to: JDMather
Sorry about that!
It will only allow me to upload three attachments, and the assembly contains 5 different part files. I will post 3 in this post and 2 in the next. Please let me know if there is a better way to do this!
Active Member
Message 4 of 7 (568 Views)
07-30-2012 06:56 PM in reply to: d3lilley
JanVarholik
Message 5 of 7 (551 Views)
07-31-2012 05:25 AM in reply to: d3lilley
Inventor complains about the missing files:
VAWT structure.iam
Shaft1.ipt
SKFEE 3ANSI.ipt
locking collar.ipt
when I try to open the attached assembly. Could you create a zip file of all missing components (and upload it), so I could take a look at it?
Active Member
Message 6 of 7 (539 Views)
07-31-2012 08:06 AM in reply to: JanVarholik
I did a "pack and go" (love that name)  and then compressed all those files into a zipped folder. Hopefully this will work!
JanVarholik
Message 7 of 7 (520 Views)
08-01-2012 05:08 AM in reply to: d3lilley
One of the ways to animate your turbine is creating two workplanes. One by selecting Shaft:1\Origin\XY Plane. This workplane will be attached/constrained to your Shaft:1. Create another one constrained to VAWT structure:1. Since both workplanes will share the same shaft axis, you can easily constrain them by angular constraint. Then you drive the constraint as needed.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
