Inventor General
Valued Contributor
Message 1 of 12 (5,252 Views)
Analyze/Show the references inside an IPT file
5252 Views, 11 Replies
09-26-2011 02:57 AM
I cannot open anymore an IPT file (an error comes up). I know that the IPT file contains multiple references to other IAM´s and IPT´s via "Derived parts"; is there a tool to show all the references inside an IPT file?
Product Support
alessandro.gasso
Message 2 of 12 (5,249 Views)
Re: Analyze/Show the references inside an IPT file
09-26-2011 04:04 AM in reply to: helmut.backs
For doing this you can select the file in Windows Explorer or from the Open dialog in Inventor, right-click, Design Assistant.
In Design Assistant, Manage view, in the upper side, select the file, if it is not selected yet.
In the lower side, select the boxes corresponding to types of file where the file has been used (or, in doubt, select all the boxes.)
Then, click on the button, Find Files.
Unfortunately, if you get an error, trying to open the file in Inventor, possibly you will get the same error or similar, opening the same file in Design Assistant.
In any case, I hope this could be of some help.
Kind regards,
Alessandro
Alessandro Gasso
Product Support Technical Lead
MFG - Inventor
Valued Contributor
Message 3 of 12 (5,245 Views)
09-26-2011 04:37 AM in reply to: helmut.backs
Also the DesignAssistent stopped working when I opened that file. I need a tool which only extracts the references! May be Autodesk can help!!!
Valued Mentor
Message 4 of 12 (5,230 Views)
09-26-2011 06:30 AM in reply to: alessandro.gasso
In Design Assistant, the derived part source files will be listed in the tree in the Properties view - no need to use the Find Files function. If a derived file is missing, you should get a dialog box with the option to Continue. The missing files will be marked with a question mark or broken link icon. You may need to hit Refresh to get these to appear.
Paul Cunningham
IV2008
Valued Contributor
Message 5 of 12 (5,228 Views)
09-26-2011 06:38 AM in reply to: pcunningham1
Sorry, but the files are there. The problem is, that the files could not be opened anymore!!!
Product Support
alessandro.gasso
Message 6 of 12 (5,224 Views)
09-26-2011 07:04 AM in reply to: pcunningham1
Paul,
You have inserted Part1 in some assemblies and derived it in some parts.
Now, you want to know in which assemblies and parts, Part1 has been used (or, at least, I think this was the question).
Well, if this is the case, you need to follow the steps I’ve shown above in Design Assistant.
Unfortunately, if Part1 is corrupted this is not going to work.
Alessandro
Alessandro Gasso
MFG - Inventor
Valued Mentor
Message 7 of 12 (5,216 Views)
09-26-2011 07:16 AM in reply to: helmut.backs
In your original post, you said 'an error comes up'. I t would be helpful if you could give more info about the specific error message.
Paul Cunningham
IV2008
Valued Contributor
Message 8 of 12 (5,210 Views)
09-26-2011 07:20 AM in reply to: pcunningham1
The error message is "Error while reading from RSe-stream (4 not equals 1)"; I translate the message because I´m using a german version; the original message which Inventor 2010 (german) gave me is "Fehler beim Lesen von RSe-Stream (4 ungleich 1)"
Valued Mentor
Message 9 of 12 (5,204 Views)
09-26-2011 07:24 AM in reply to: alessandro.gasso
The way I read the question, he's asking about the derived part/assy references inside a part file. AFAIK, the are no 'where-used' references stored inside part files.
Paul Cunningham
IV2008
Product Support
alessandro.gasso
Message 10 of 12 (5,202 Views)
09-26-2011 07:26 AM in reply to: helmut.backs
Did you check if in the OldVersions folder of your project there is a previous version of this file that can still be opened?
Thanks and regards,
Alessandro
Alessandro Gasso
MFG - Inventor
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
