I have reason to suspect a lot of us are wondering what are the
corresponding improvements in performance due to factors such as choice of
driver, OpenGL tweaks, registry hacks, etc. and a system specific analysis
with a reliable benchmark tool is the only way this can be achieved. One
where numbers can be generated and you could feel reasonably certain these
numbers were realistic. It hasn't been disproven that the benchmark tool
before us isn't one we can feel comfortable basing these numbers on. Albeit
the exercise is time consuming for any individual.
"Sean Dotson"
wrote in message
news:700056FCB51BCA417F8E3BC700EE0D07@in.WebX.maYIadrTaRb...
> oops that's in FPS, sorry... so not quite as good as the 750s
> Sean Dotson, PE
> http://www.sdotson.com
> Check the Inventor FAQ for most common questions
> "Sean Dotson" wrote in message
> news:E832AE2740623D3A31E9F49583CF85A0@in.WebX.maYIadrTaRb...
> > For what it's worth...I have a 700XGL and these are my results (P4
2.0GHz,
> > 1/2 gig ram)
> > Shaded = 22.1 FPS
> > Hidden = 8.1 FPS
> > Wireframe = 16.6 FPS
> > Multiple Windows = 23.3 FPS
> > Average = 17.5 FPS
> > better than a lot of the 750s
> > Sean Dotson, PE
> > "Jack Brentner" wrote in message
> > news:64327BFACA760CBA23645078A68DFB35@in.WebX.maYIadrTaRb...
> > > Yes I suspect as such. I'm not even sure the MB supports beyond AGP
1X.
> I
> > > purchased the 750 XGL at the time there was a promotion from PNY and
> > > solidjerks for $399 - couldn't pass it up. The Voodoo5 card was pukin'
> and
> > > diein' on the XP operating system, and 3dfx underground drivers turned
> out
> > > to be vaporware.
> > > Would like to see a similar analysis for the 750 XGL in a worthy
system,
> > > like oh say a dual 2.0 Xeon 😉
> > > Again, the results indicate that a low-end machine (read P3) will not
> > > respond to differing input.
> > > Thanks Many,
> > > Jack
> > > "Andy Shelter" wrote in message
> > > news:923BEBFEDA08B0AFE2D358AFAA819AEC@in.WebX.maYIadrTaRb...
> > > > Jack,
> > > > I'm excited about your extensive tests.
> > > > After viewing your system specs I come to this conclusion:
> > > > Your system seems to have a bottleneck with your P3-650 because your
> > > results
> > > > are so bad. On other systems the 750XGL gets about 30FPS in shaded
> mode.
> > > On
> > > > your system only 10 FPS.
> > > > You can not see any different results because your graphics board is
> > > waiting
> > > > on the CPU in EVERY case.
> > > > The results on other systems are very different because of
> > > > - different hardware (CPU, GPU, memory)
> > > > - different Inventor graphics settings (I recommend to use IV
default
> > > > settings to assure we compare apples with apples)
> > > > - different OS, different displaydriver and displaydriver settings
> (this
> > > is
> > > > probably the smallest factor)
> > > > Andy
> > > > news:5199353292B5E6F4BEE877981CD1D6F6@in.WebX.maYIadrTaRb...
> > > > > One can postulate any number of new hypotheses.
> > > > > To name a few:
> > > > > H1) The benchmark results are suspect.
> > > > > H2) The test equipment does not respond as expected to the chosen
> > > inputs.
> > > > > H3) Significant result differences are driven by other
unidentified
> > > inputs
> > > > > or combinations thereof.
> > > > > Verification of
> > > > > H1: Run similar trials with another benchmark tool.
> > > > > H2: Perform similar trials on other equipment with the same
> benchmark
> > > > tool.
> > > > > H3: Choose other inputs or parameters and combinations thereof and
> > > re-run
> > > > > (hardware, op system, other opengl tweaks, etc.).
> > > > > One can draw no other conclusion from my analysis other than that
> "the
> > > > > benchmark provided no significant different results with the
inputs
> > > chosen
> > > > > on that particular machine". At the least, my results must be
> > confirmed
> > > > > independently before any other conclusions can be drawn.
> > > > > Thanks Many,
> > > > > Jack
> > > > > "Ron Crain" wrote in message
> > > > > news:EF089B81EB15AD063E42823F17687CA6@in.WebX.maYIadrTaRb...
> > > > > > Very interesting.
> > > > > > I said it in Andy's thread and I'll say it here. I don't trust
> > these
> > > > > > numbers.
> > > > > > news:1013E178544D2FC0DA171760A7AFCC88@in.WebX.maYIadrTaRb...
> > > > > > > Using Andy Shelter's excellent graphics benchmark, I ran it
lots
> > of
> > > > > times
> > > > > > > with different nVidia drivers, OpenGl tweaks, suggested
registry
> > > > hacks,
> > > > > 1
> > > > > > > and 2 monitors, and with/without the statistics posting
onscreen
> > > hack.
> > > > > > > In all but one trial, I rebooted the machine between trials.
> > > > > > > Short of a Chi-Squared statistical analysis, my instincts tell
> me
> > > that
> > > > > > there
> > > > > > > is no significant difference in the results with ANY
combination
> > of
> > > > > > > settings.
> > > > > > > See Excel spreadsheet posted in CF.
> > > > > > > -Jack
