Dan,
Did you use UNC naming in the Project File?
I know Hal is a proponent of this format (and it's good/fast as long as
the server doesn't blow up and need to be renamed), but if the IPJ is
set to a relative file structure, it would seem to me that there should
be no resolution problems.
Anyhow, try the migration assistant and see if it will walk through the
children folders and update the children to their "new" parents. (set up
a new IPJ to do this)
QBZ
"dan_mayers" wrote in message
news:f187561.-1@WebX.maYIadrTaRb...
> We had a server meltdown and have had to rename the main server for
our iParts. I am now finding that many of the children (not all) are
still trying to look to the old server for the iPart factory. From the
Sean's tutorial, I had understood that the project file should be
telling the children where to look for the parent file, and had set up
our project files to support this.
> Am I pulling a stupid, or is this not the way it is supposed to work?
> Is there a way to get the children to update other than opening each
individual file and resolving them?
> Thanks for your help!
> Dan
