Does anyone know where I can downlaod this mateiral?
I am currently working ona project that requires 2024 T0, T3, and T6 grade Aluminum.
If you know the specifications of those materials you can make them by editing existing aluminums in the material library.
You can get your properties for your 2024 Aluminum materials then place those properties into a new material within the Inventor styles.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
