Inventor General
New Member
Message 1 of 4 (155 Views)
Alternative Packages not recognising Spline
155 Views, 3 Replies
01-23-2013 06:01 AM
I am drawing an airfoil profile in Inventor for use in a CFD package. I have a system of points which I am plotting and connecting via the spline function and extruding them to form my blade profile. However, when I open the drawing in the CFD programme, it is recognising the spline as a series of straight lines instead of one continuous enclosed shape. The CFD programme I am using require a negative (i.e a solid drawing of where fluid is flowing). I have attached the inventor file I have created. I have a feeling there is probably a very easy fix to this problem. Any help would be greatly appreciated.
Sean
Employee
Message 2 of 4 (106 Views)
Re: Alternative Packages not recognising Spline
01-24-2013 09:46 AM in reply to: Sean.cooke
Hi Sean,
Welcome to the forum!
I'm sorry to hear that you're having trouble. If you zoom in on Sketch1 you will see that you are in fact creating a series of straight lines from the beginning (see screen capture below).
I also noticed that your sketches are unconstrained; are you new to Inventor? If so, you may find JD Mather's SkillsUSA document of use:
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Please feel free to follow up with anything else - hope this helps.
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk ShapeManager
Design, Lifecycle and Simulation
Autodesk, Inc.
New Member
Message 3 of 4 (94 Views)
01-24-2013 10:59 AM in reply to: wilkhui
Thank you Wilkhui,
I managed to fix the problem this afternoon. I redrew my airfoil blade in inventor and there was no problem with my CFD package recognising it correctly. Im not new to inventor but I am quite rusty, it has been about 3 years since I have used it last.
Thanks again for taking the time to look at my problem,
Best Regards,
Sean
Employee
Message 4 of 4 (89 Views)
01-24-2013 11:14 AM in reply to: Sean.cooke
Hi Sean,
No problem at all - glad to hear that you've got it to work for you :smileyhappy:
Please don't hesitate to get in touch should there be anything in future and happy CFD'ing!
Best wishes,
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk, Inc.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
