Inventor General
Distinguished Contributor
Message 1 of 5 (454 Views)
Accepted Solution
Alternate Units on Hole notes.
454 Views, 4 Replies
10-25-2012 12:29 PM
I am using 2012 SP2 and when I try to place hole notes with both metric and inches it only gives me inches (in both displays)  See screen shot.
*Pro
sbixler
Message 2 of 5 (429 Views)
Re: Alternate Units on Hole notes.
10-26-2012 04:21 AM in reply to: shastu
Post screen shots of the dimension style showing the Alternate Units tab, and the Notes and Leaders tab (with the appropriate type of hole note selected).
Message 3 of 5 (411 Views)
10-26-2012 06:06 AM in reply to: shastu
*Pro
sbixler
Message 4 of 5 (401 Views)
10-26-2012 06:24 AM in reply to: shastu
Edit the hole note (or change the style if it applies to the whole drawing) and uncheck the Part Units checkbox under Options.  Your model is apparently in inches, so by default that's what shows in hole notes.  Uncheck that, and it will use what your drawing style calls for.
Message 5 of 5 (374 Views)
10-29-2012 06:30 AM in reply to: shastu
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
