Thanks, Q. The undo thing is exactly what I was looking for. Question...is there
a way to D-and-D parts from existing to existing? I am thinking I should have
used a Master, but too late now.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"Quinn Zander" wrote in message
news:5355BB3C6B47A6F03D8DBCBDB2639EF9@in.WebX.maYIadrTaRb...
> Dave,
> You could select all your needed parts in the main assembly and demote
> them into a sub. Save the assembly, but say NO to saving the main
> assembly(just save the new sub). Now hit Undo (since the sub was saved
> to disk and you want all your original parts back) and place the new sub
> into the main assembly.
> Set the new sub's occurence to reference.
> The Drag and Drop thing works if you are dropping parts into a new sub;
> demoting in effect. Grabbing them all at once will keep any
> relationships between the selected set of parts as they are being
> stuffed into a new sub... drag n drop one at a time will keep their
> position, but no interelated constraints.... plus you'll have a wack of
> undo's to do after the false save.
> Before doing any of this, I'd recommend bumping your oldversions up a
> couple of notches-just a personal experience thing 😉
> QBZ
> "Dave Jacquemotte" wrote in message
> news:FD5AC42BA45E3AA0214E41F336C127DF@in.WebX.maYIadrTaRb...
> > Please refresh my memory...
> > I would like to create an alternate position sub-assembly. I know all
> about
> > setting it to reference and all that. The part I forget is, is there
> an easy way
> > to keep the parts just like they are now in the main assembly
> (constrained, not
> > subassembly) and still select the parts to be put into alternate
> position? I've
> > seen people say use drag-and-drop but it does not seem to be working
> as I
> > expected. Please advise. Thanks.
> > Dave Jacquemotte
> > Automation Designer
> > www.autoconcorp.com
