Inventor Forum
Align Multiple Text Blocks
9 REPLIES 9
Message 1 of 10
chris31
1633 Views, 9 Replies
Is there a way to horizontally ( and also vertically) align multiple text blocks? I'm preparing some drawings for a catalog, and need to get the Text blocks horizontally aligned.
9 REPLIES 9
Message 2 of 10
chris31
in reply to: chris31
I should have said this is with IV2013.
Message 3 of 10
Curtis_Waguespack
Hi chris,
If you create that text in a sketch, you can use sketch constraints to align the text. Recall that if you select the drawing view first, then click the Create Sketch button that it will associate the sketch to the view, so that if you move the view, the text will move also.
I hope this helps.
Curtis
Message 4 of 10
rdyson
Create a sketch on the sheet (not view)
Create a sketch only line
Add your text blocks in this sketch and constrain to the line.
PDSU 2016
Message 5 of 10
chris31
I'm not seeing how to align the text blocks though on an idw.  Which contraint will horizontally align the text blocks?  Either on a sketch or not...
Thanks!
Message 6 of 10
Curtis_Waguespack
Hi chris,
In a sketch you can use the Horizontal constraint to align the text insert point. You could also right click the text and choose Text Box, and then use the Collinear constraint on the text boxes.
I hope this helps.
Curtis
Message 7 of 10
JDMather
Align Text.pngFast way - Ctrl select the text.
Right Mouse Button select Align
If you want to set in stone (constrain), display the text box and constrain as suggested.
Message 8 of 10
chris31
in reply to: JDMather
TOO DAMNED EASY!!!
Message 9 of 10
Curtis_Waguespack
@CHriS wrote:
TOO DAMNED EASY!!!
Sorry for taking you the long way about. Smiley Embarassed I actually didn't know that ability was there.  Kudos to JDMather!
Message 10 of 10
chris31
in reply to: Curtis_Waguespack
I get aggravated at myself when the answer is so obvious, and I never even looked for it. Online help did not even have this handy tidbit...
