Inventor General
Message 1 of 5 (281 Views)
Accepted Solution
Air Trap Analysis 2012
281 Views, 4 Replies
10-16-2012 11:35 PM
Somebody help me.
I can't find the air trap analysis for 2012. it says it does not run such analysis in 3D. For some parts however, it did run. Is there any way to solve this problem???
Valued Contributor
Message 2 of 5 (269 Views)
Re: Air Trap Analysis 2012
10-17-2012 12:28 AM in reply to: ericjed13
Well, run the 2.5D flow analysis on the surface mesh defined by the 3D mesh. It should show the airtraps.
Message 3 of 5 (258 Views)
10-17-2012 01:06 AM in reply to: abakharev
Okay, and how do i do that exactly? :smileyfrustrated:
Valued Contributor
Message 4 of 5 (212 Views)
10-17-2012 09:40 PM in reply to: ericjed13
Select your study.
Right click on the 3 D Mesh label:
In the Pull-down menu select Set Mesh Type.
Choose Dual Domain.
The label now is is Dual Domain Mesh. If the surface mesh were present, you would see some some none zero number of elements. If the surface mesh was not stored in the study you would see 0 elements:
Right click on it once more and select "Generate mesh".
After meshing is finished start the analusis and enjoy the Air Trap plot.
Message 5 of 5 (206 Views)
10-17-2012 10:26 PM in reply to: abakharev
Wow! Thanks for that!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
