Inventor Forum
After close part (of an assembly) i see the bar of parts in the assembly?
6 REPLIES 6
jakob
236 Views, 6 Replies
sometimes, when i close the part of an assembly, i turn back to my assembly with the bar of parts. I have no possibility to click something in the part-bar. Then i must kill the inventor process and then it works.
Some idea?
ps: I don't know the right title of bar, because i have a german version.
system:
WinXP SP2
AIS11 with SP3a
6 REPLIES 6
andrewiv
in reply to: jakob
I've had this problem before. If you can select parts in the graphics window, try to double click on one and edit it. Then simply RMB finish edit and it should be fine.
Andrew In’t Veld
Designer
in reply to: jakob
"I don't know the right title of bar," = browser
What graphics cards do you have?
What g/card drivers do you have?
Do you have the latest configuration file for your g/card, from Adsk
http://www.inventor-certified.com/graphics/registries.php
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by
fabricated insanity that nothing could be as mad as what passes for ordinary
living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:5749647@discussion.autodesk.com...
Some idea?
system:
WinXP SP2
AIS11 with SP3a
jakob
in reply to: jakob
@andrewiv: No, i mean, that I can't select anything in the bar. I will try it when the problem occurs again.
@Duncan Anderson:
Browser? Is this not the window of inventor, where i can see the parts in the tree. I mean the button-bar for extrusion and so on.
Quadro FX 3500 (PCI-E) with the newest dabase und 91.36 driver. I use OpenGL under AIS11.
An other PC with the same configuration do not have this problem.
JDMather
in reply to: jakob
Can you do a screen capture and save in MS Paint as jpg file.
On English keyboard you can capture the screen by hitting the Print Scrn key in upper right hand corner of the keyboard and then past into MS Paint. In Paint draw a circle around problem.
It sounds to me like you are trying to do an Assembly level Extrusion with no sketch but between the language difference and no example I'm not sure.
You might also try posting your question in German as there are other German speakers here.
jakob
in reply to: jakob
Here the screen capture.
Ther return-button (in german: Zurück) do not work!
in reply to: jakob
Hi! If you can find a workflow causing this to happen again, please let me
know asap.
Thanks!
Johnson Shiue
Inventor QA Tech Lead, Autodesk
johnson.shiue@autodesk.com
Some idea?
system:
WinXP SP2
AIS11 with SP3a
