Inventor Forum
Advise on getting the bevel right..
7 REPLIES 7
Message 1 of 8
cahoe
699 Views, 7 Replies
I've got a semi-complex drawing from sketchup of an geometric telefoneboothkindathing. The measurement from sketchup is all over the place and to no use. So I end up with one serious problem.
The top and righthand side connects and is together cut of to make a new angle on which a little piece of front is surposed to mate on.
Now I can't figure out the degrees of  bevel on respectivly the top part and righthand part to form an unison plane on wich to constrain the front piece.
Any advice?
either way.. have a very nice weekend. Here the sun is shining.
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: cahoe
I would use multi-body solids technique.
Attach your ipt file here if you get stuck.
Message 3 of 8
cahoe
in reply to: cahoe
Hmmm.. "the multi-body solid techique" sounds HOT!
Just not quite clear on what that implies..?
In the mean time I've got stuck so any analytic skills used on the attached file would be very very helpfull.
Thanks in advance and by chance 😉
Message 4 of 8
jddickson
in reply to: cahoe
Here is something that might help you. This is probably not the easiest or the fastest way to do this but it will give you all the finished angles you need. The only reason for doing anything like this would be to figure out something with mutable compounding angles.
1st out of one part you can make the make the inside shape of your enclosure.
2nd use the thicken/offset command on every face.
3rd you can use the measure angle between the thickness /  2 and repeat that’s how you can get all of your angles
Attached I used your files to make an example. I made a surface using one of your parts. I would not suggest making your inside shape that way. I just did it that way because I didn’t have a clue what your finished product needed to look like.
I hope that made some kind of sense and help you in some kind of way...
Message 5 of 8
cahoe
in reply to: jddickson
Dear JD..
You really got out of your way to help me here .. thanks.
Have been away from the project a while and have just looked at your file and it is very interessting even tho it's clearly a little bit outta my league. But I'm shure this will lead me to valuable insights to pro handling of inventor.. Thanks a LOT! 😉
Message 6 of 8
cahoe
Actually some of things you have used to do this is so interessting that I would consider paying you to do a videotut 😉
Any good leads to learning materials btw?
Message 7 of 8
jddickson
in reply to: cahoe
Cahoe,
Thank you.
This video is similar to some of the things I did.
http://www.youtube.com/watch?v=vaJE6N3jHXE
JD
Message 8 of 8
cahoe
Pretty darn awesome.. thanks!
