I am coming to Inventor from years of using SolidWorks where this is never an issue as everything snapped to each other and I just can't figure out how to do it here.
For example, if I have one sketch in the XY plane, consisting of a circle and then in the XZ plane I am trying to draw a second sketch consiting of a line that intersects with the circle (i.e. where the circle intersects with the XZ plane). How do you relate one sketch to another?
Hi munkifisht,
You can use the Project Geometry tool to do this:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-5FBFED0C-530B-480A-8DEE-E8B8BF7D385F
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-58C2C0CE-63AF-42CE-BAFB-53C9AF248840
Note that there are some settings that can be turned on to assist with Projected Geometry.
Tools tab > Application Options button > Sketch tab
I hope this helps.
Curtis
Hi Munk,
You have to use project geometry.
You can find the file attached.
I hope that it can helps you.
Admaiora
Ops.
Sorry for double solution
Admaiora
Inventor does not automatically project from one sketch to another like SWx.
The Project Geometry tool suggested above is the equivalent of the Convert Entities tool in SWx.
There are some autoprojection settings in Inventor, but I prefer to disable all of these and project only what I want.
