Inventor General
*Maenpaa, Mike
Message 1 of 6 (123 Views)
Adding trail problem in IPN
123 Views, 5 Replies
11-01-2002 12:48 AM
Has anyone ever come up with a solution to this? I'm experiencing the same
problem. See .jpg in Customer Files.
Mike
"Derek" wrote in message
news:6270C3897DD10962F6A2FE2855C3D54E@in.WebX.maYIadrTaRb...
> The other thing is after I did what you told me to do, I zoom all and I
> found those trails but they were about twenty feet from the location of
> where I want the trails to be...
> Derek
> "KJohnson" wrote in message
> news:43DBECCF4127B9C89A38E11B0875148E@in.WebX.maYIadrTaRb...
> > You need to unhide trails. Then rmb the trail you don't won't and click
> > visible. The other option is to define the trail origin when making the
> > tweak in the first place. Good luck
> > Kathy Johnson
> > news:90E3A83034ECBB5B28A55D4CD3CBE12B@in.WebX.maYIadrTaRb...
> > > I already look thru the posts from awhile ago but that didn't solve my
> > > problem. I need to know how can I add trail to a different location on
> the
> > > sub assembly such as the hole instead of the center of the part. First
> of
> > > all, I did the tweaking without the Display Trail checked. Then I went
> to
> > > add trail from the center of hole but it never appeared... Can anyone
> tell
> > > me what I am doing wrong?
> > > Thanks,
> > > Derek Sevier
> > > Mechanical Engineer
> > > Quality Corporation
> > > 2401 S Delaware St.
> > > Denver, CO 80223
> > > derek.s@donkeyforklift.com
> > > Fax: 303-777-6488
*McConnell, Cory
Message 2 of 6 (123 Views)
Re: Adding trail problem in IPN
11-01-2002 01:09 AM in reply to: *Maenpaa, Mike
Yes . Don't know how to fix it. I think it might have something to do with
previous tweaks?
Cory McConnell
BJ Pipeline Inspection
*Maenpaa, Mike
Message 3 of 6 (123 Views)
Re:
There were no other tweaks in this case. I started from scratch.
Mike
"Cory McConnell" wrote in message
news:87368E24E8D53DDAB47827F3EE4B928F@in.WebX.maYIadrTaRb...
with
> previous tweaks?
> Cory McConnell
*McConnell, Cory
Message 4 of 6 (123 Views)
Re:
11-01-2002 01:18 AM in reply to: *Maenpaa, Mike
There goes that theory. I have probably never tried to add a trail to the
first tweak.
Cory McConnell
*Maenpaa, Mike
Message 5 of 6 (123 Views)
Re:
Ok, I just figured out a workaround for my case. The part I was tweaking was
actually a sub because of the PEMS. I tweaked all the parts separate (but
the same distance) and added the trails to the PEMS. Trails now appear like
I want them.
Mike
news:8AB4976FA4B2AC873E446E5D2EE3C9ED@in.WebX.maYIadrTaRb...
the
> first tweak.
> Cory McConnell
*McConnell, Cory
Message 6 of 6 (123 Views)
Re:
11-01-2002 01:36 AM in reply to: *Maenpaa, Mike
I usually end up fooling around until I get around it. Sorry I couldn't
help.
Cory McConnell
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
