Has anyone ever come up with a solution to this? I'm experiencing the same
problem. See .jpg in Customer Files.
Mike
"Derek" wrote in message
news:6270C3897DD10962F6A2FE2855C3D54E@in.WebX.maYIadrTaRb...
> The other thing is after I did what you told me to do, I zoom all and I
> found those trails but they were about twenty feet from the location of
> where I want the trails to be...
> Derek
> "KJohnson" wrote in message
> news:43DBECCF4127B9C89A38E11B0875148E@in.WebX.maYIadrTaRb...
> > You need to unhide trails. Then rmb the trail you don't won't and click
> > visible. The other option is to define the trail origin when making the
> > tweak in the first place. Good luck
> > Kathy Johnson
> > news:90E3A83034ECBB5B28A55D4CD3CBE12B@in.WebX.maYIadrTaRb...
> > > I already look thru the posts from awhile ago but that didn't solve my
> > > problem. I need to know how can I add trail to a different location on
> the
> > > sub assembly such as the hole instead of the center of the part. First
> of
> > > all, I did the tweaking without the Display Trail checked. Then I went
> to
> > > add trail from the center of hole but it never appeared... Can anyone
> tell
> > > me what I am doing wrong?
> > > Thanks,
> > > Derek Sevier
> > > Mechanical Engineer
> > > Quality Corporation
> > > 2401 S Delaware St.
> > > Denver, CO 80223
> > > derek.s@donkeyforklift.com
> > > Fax: 303-777-6488
