Is it possible to add notes for each hole in a hole table?
I want to add for each hole in a hole table its true position value that I decided (instead of creating feature control frame for each hole).
Solved by Curtis_Waguespack. Go to Solution.
Solved by blair. Go to Solution.
Could you please attach some sample file (part, assembly, or image) to better understand what exactly you want to obtain?
Hi sbachar,
Try these steps:
Note: this edits just that hole table, you might want to do this for your Hole Table style as well if you intend to have a notes column in all of your hole tables going forward.
I hope this helps.
Curtis
You can scrub the Vert and Hor lines to place the Target Datum where you want it. Still keeps the parameters linked. Or add a sketch to the view with a point to attached to.
You can do what Curtis has offered, myself I would keep it "linked" and not add over-ridden values. It's to easy to overlook then manually added values should the model change is some way.
@Anonymous wrote:
... myself I would keep it "linked" and not add over-ridden values. It's to easy to overlook then manually added values should the model change is some way.
Hi sbachar,
I agree with blair.
In my previous reply, I skipped the "why" of your question and answered just the "how". But in review, I think it would not be wise to add the information you mentioned as a note.
I hope this helps.
Curtis
