Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
Did you mean:Ā
Adding force in frame analysis
2 REPLIES 2
Anthony
685 Views, 2 Replies
I have a question regarding adding a force constraint in the Inventor frame analysis environment. When I add the fixed constraint to the beam the orientation indicator is incorrect - the square indicator being not parallel to the base of the beam. I would like to know why this is and as I am relatively new to frame analysis if I am doing something wrong. I have attached a screen shot of the placement of the constraint on the beam. Thank you
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
2 REPLIES 2
JDMather
in reply to: Anthony
Define the direction of Gravity before anything else.
Anthony
in reply to: JDMather
That did the trick, many thanks Smiley Happy
