Inventor General
niall.smyth
Message 1 of 6 (511 Views)
Adding Text Parameters to Parts Published to Frame Generator
511 Views, 5 Replies
01-28-2013 07:47 PM
I can publish a part containing a user text parameter to the content centre for use in frame generator however when I go to insert that part an error as per the attached screen shot.
To re-create the error you have to follow the below steps.
  1. Create a part with a text user parameter
  2. Publish for use in frame generator.
  3. Create frame with the part and an error will be created as per the attached screenshot.
Is there a way to work around this error being created and use parts with text user parameters in Frame Generator?
Thanks in advance for any advice!
Valued Contributor
VdVeek
Message 2 of 6 (487 Views)
Re: Adding Text Parameters to Parts Published to Frame Generator
01-29-2013 01:51 AM in reply to: niall.smyth
What do you mean by : Create a part with a text user parameter?
I can't recreate your the error. Which inventor version do you use?
Autodesk Inventor 2012 Certified Associate & Autodesk Inventor 2012 Certified Professional.
niall.smyth
Message 3 of 6 (468 Views)
01-29-2013 03:44 PM in reply to: niall.smyth
I am using Inventor 2013 with service pack 1.1. and update installed.
When creating a part, go into the parameter table editor and add a text user parameter, you do not even have to assign a value in the equation column.  Just add a text user parameter and then create some geometry such as a square or circle and extrude so that you can publish the part as a structural member for use in frame generator.  Attached is a screen grab showing the parameter editor and a user added text parameter.
Cheers,
N
Valued Contributor
VdVeek
Message 4 of 6 (457 Views)
01-30-2013 02:12 AM in reply to: niall.smyth
I'm using Inventor Prof 2012 SP2 64-Bit and i can reproduce your error when placing an user parameter.
Looks like a bug to me. The Numeric option is working, but the text and true/false are giving the same error.
Sorry I can't help you. Ask Autodesk for some help.
Rob.
Distinguished Contributor
cparnell
Message 5 of 6 (442 Views)
Thanks for posting.
01-31-2013 04:57 PM in reply to: niall.smyth
Niall:
I have had the same issue for a week or so now, and your post help me solve my issue. I could not figure out why I could publish other parts and save the iterations from Frame Generator and this other file I could not.
Thanks again for posting your fix.
*Expert Elite*
LT.Rusty
Message 6 of 6 (427 Views)
Re: Thanks for posting.
02-01-2013 10:12 AM in reply to: cparnell
Text parameters don't work in iParts / Content Center / Frame Generator parts.  It's not a bug, it's just the way the software was made.  One of my fondest dreams is that this will change for 2014 ...
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
