Inventor General
New Member
nickolas.jaderas
Message 1 of 4 (741 Views)
Adding Custom iproperties with iLogic
741 Views, 3 Replies
11-02-2010 03:23 AM
Hi!
Is it possible to automatically add custom iproperties using iLogic?
I have a rule thats adds text to a propery, but when I run the rule in an old partfile i get the error:
"Can't find a property named DrawingNo"
Is there something like:
"Create iProperties.Value("Custom", "DrawingNo")"?
PaulMunford
Message 2 of 4 (721 Views)
Re: Adding Custom iproperties with iLogic
11-02-2010 06:29 AM in reply to: nickolas.jaderas
Read Up on this article:
http://modthemachine.typepad.com/my_weblog/2010/02/custom-iproperties.html
All of the VB stuff that Brian describes can be applied to iLogic. Just remember to observe VB.net rules (i.e. 'Get' and 'Set' aren't required) and don't forget that you can use iLogic's built in functions to get the current document.
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
New Member
nickolas.jaderas
Message 3 of 4 (715 Views)
11-02-2010 06:41 AM in reply to: PaulMunford
Super!
I will try read and try the examples:smileyhappy:
actually what i wanded it to do: (for using the substitution function in the partlist)
if iProperties.Value("Custom", "Part have drawing") = True
iProperties.Value("Custom", "DrawingNo")= "=ACC TO DWG <Project>-<SubNo>-<ItemNo>"
else if iProperties.Value("Custom", "Part have drawing") = False
iProperties.Value("Custom", "DrawingNo")= ""
end if
Active Member
Message 4 of 4 (173 Views)
12-20-2012 11:23 PM in reply to: nickolas.jaderas
in the tutorial not included how to delete the custom properties.
can anyone help me?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
