Inventor Forum
Adding Barcode to a drawing
13 REPLIES 13
Message 1 of 14
feldwill
10349 Views, 13 Replies
Is there a way to add barcode to a drawing which is a translation of Drwg. #.
I saw iPropWiz program but don't know if that's the way to go.
W
13 REPLIES 13
Message 2 of 14
mcgyvr
in reply to: feldwill
Yes, you simply need to have the bar code font in your windows font folder then place text and use the parameter you want and change its font to your barcode font.. Don't forget if using code 39 or whatever you might need to put an asterisk before and after the parameter (for stop and start signals)
Message 3 of 14
another tip is to set the start and stop asterisk to a smaller size if that's the convention, see attached
Message 4 of 14
MaxU77
Bmiller63,
Does the font "IDAutomationC39M" free?
MaxU77,
AI2011 Certified Associate
(Soft: PDSU2012, VP2012&VP2013)
Message 5 of 14
I don't recall where I got them, but most likely installed with some other application.
Here is the website, there are at least some free ones here:
http://www.idautomation.com/fonts/
Message 6 of 14
delineryan
This font file works too.
Ryan
Message 7 of 14
mboelke
in reply to: delineryan
We are currently using Code 39 as the font for our bar code on our drawings.  If we want to create a pdf of the drawing we must eliminate this field off our drawing and then create the pdf.  I have tried the font Free 3 of 9 and it will work when I create the pdf but our bar scanners can not read it.
Does anyone know why creating a pdf with the font Code 39 on the drawing would crash Inventor?
We are currently using IV 2011 but it also did this in IV 2010.  We will be upgrading to IV 2012 soon.
Dell Precision T5500
64-bit Windows 7 Pro SP1
Intel Zeon X5550 @ 2.67GHz
Nvidia Quadro FX 4600
Message 8 of 14
Raider_71
in reply to: mboelke
Hi I was doing a bit of research regarding this and found the follwing website that might be of help: http://www.barcodingfonts.com/embed-barcode-pdf.htm
It looks like you need a special fornt for that to work.
Cheers
Pieter
Message 9 of 14
mboelke
I found that if I use PDF Creator it will embed the font Code 39.  It will only not work if I export the pdf from Inventor.
Message 10 of 14
swhite
Yah, inventor's pdf leaves a lot to be desired. I use the free bullzip printer to create all my pdf's, plus you can print as a jpeg, tiff, etc too. plus they have a few other nifty ones like pdf to word.
http://www.bullzip.com/
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Message 11 of 14
scottmoyse
Use a font as mcgyvr & the others said. Then you will need to set up a text style in your drawing which will use that font. From there you will need to create a custom iProperty, then when you fill in the value for that property type in:
=*<propertyname>*
Where propertyname is the name of the property you would like the barcode scan result to be. I've included the required asterisks assuming the use of the 3of9 or 3of9extended barcode fonts. Depending on the 3of9 font you use, you may need the extended version if your property contains special ASCII characters.
Then insert your custom property where ever you need it on your drawing.. title block, custom parts list, balloons, symbols....
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 12 of 14
mboelke
in reply to: scottmoyse
Yes, it exports well as a pdf using PDFCreator.  Code 39 font has no ill effects on it.
Message 13 of 14
cindy313
sorry for reply as it is sovled ! i just wondered must it be coe 39 ? how about any another ones?
Message 14 of 14
cindy313
if there is ,what ill effects it is
