Im not sure if this has been posted before so I apologize for a re posting if I am. But..
Im in the middle of creating a video using Inventor 2012 and I need to add more time to my starting camera and a few places in the middle of the video. Is it possible to kind've "insert" time. For example I want to add 10 more seconds to the beginning before any animation happens, I have animation starting at 0.0 and need to change it. I know I can one by one click every block in the timeline and simply move everything over 10 seconds, but I have a lot of animations on suppressions and constraints and clicking everything would simply be to time consuming.
If anyone could help it would be much appreciated, Thank you in advance.
Solved by Dennis_Jeffrey. Go to Solution.
If you have already created the video, you could use Camtasia, Adobe Premier or other video editing software to extend segments.
Thank you for your reply, I thought about doing something like that with the video with camtasia or vegas pro, but certain part animations happen at certain times so If I just add time in places after the video renders, then certain segments wont end up on the right time anymore. I had to just click and drag everything selecting only certain parts. Thanks anyway!
