Hey everone:
I've got an interesting question. I've got an iFeature created that's very handy. It's basically a reamed hole with a counterbore for a purchased locating pin.
Here's the rub: Is there a way to specify a tolerance to that hole that will come through the iFeature? As in, I can draw the hole with a diameter of 0.501" within the defintion of the iFeature. That's easy. However, when I do a print, I'd like to be able to just snap a leader to it that will have the "Use Part Tolerance" box checked and will refect the correct tolerance.
As an aside, one of the reasons I want to do this is because I use Hole Tables a lot. In a hole table, I can manually go in and change the callout for the hole to show the correct tolerance, but in order to keep the grouping together, I have to do EVERY hole individually.
Is there an easier way?
Thanks!
