Can onyone offer any thoughts on why my Add Ins keep unloading themselves in between sessions of Inventor. I have seen it happen when my Inventor crashes to desktop, but lately it's every time I open the software.
Only thought I have is that I'm running the Job Processor on this machine, and from time to time it also suffers errors processing visualization files. Could this be causing my Add In settings to crap out when I close Inventor?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I know this is an old post, but did you ever find a reason/solution to this?
We have 2 machines now, that keep dropping their addins, full re-install of Vault/Inventor 2013 hasnt fixed the problem.
Both machines have been used as "job servers" - that's the only thing we can narrow it down to.
Our IT "guru" is stomped
I never did get an answer to this one, but I can say that we have stopped using the Job Processor, and I haven't had this issue since. Circumstantial, I know, but....
Does the JP crash out on you a lot?
Chris Benner
Mike, yes... at least for my part. When I was having this problem, all add ins would be auto loaded, something (can't remember the details) would crash me, and when I restarted IV, all add ins would be unloaded and the "autoload" check box was unchecked. I have not had this problem in a very long time.
Looking at the date of my OP... this was before we went to 2013 also.
Chris Benner
Inventor "writes" all changes to settings upon proper closure of the software. If changes are made to settings and IV crashes, then the setting changes will lost.
Possibly the Add-in are causing the crash and IV will not load them again on start-up (just a guess, some form of protection).
Possibly problems with the Windows User Profile and/or insufficient user privileges not allowing the Windows Registry to be updated.
Yup Mike - they are also automatically loaded here. It's a very strange problem to be honest.
We only tested the job server on those 2 PCs for a few days, then stopped using it because it was causing too many issues. This being the most annoying one (another being that it crashed a lot... we were gonna set up a dedicated server to get the job done properly).
The really strange part for us tho, is that it's a really persistant issue, we re-installed vault 2013 + inventor 2013 on one of the PC's - and occasionally it still drops all addins. Occasionally being a few times a week.
I think I am having the same problem. As of Friday I can no longer save my .idw's to AutoCad.dwg.
I get a "failed to initialize 2d translator" error.
I tick the load option for dwg convert in the add-ins tab.
Try to save, get above error.
Go back to add-ins tab, the option has unticked itself.
And of course it has to happen on the day that I need to send 2 different companies AutoCad copies!
-Inv2013 Pro
Hmmm Barry ... do you use Avast Antivirus?
As a matter of fact I do....Come on Autodesk, the promised land of Linux is waiting for you.
Disabled all shields-no change. I have made no other changes to my software other than Avast updates.
Its almost as if the damage is done.
Uninstalled Avast and deleted folder from the regristry, no change.
Maybe a fresh install would be quicker at the end of the day.
Sorry to hear that ... stomped on my issue as well. We'll just live with it untill we need new workstations 😃
Did you guys look into Blair's suggestions? He is likely on the right track. Do you guys have local administrative privileges on your machines? When you installed did you follow the AutoDesk Software Installation Guide?
We have local admin rights on our workstations yes. I can guarantee that the guide wasn't followed point for point.
Our IT department is .. challenged .. they ghost the machines with old updates for just about everything (example our grafichs driver is from 2011) and grunt and growl when we suggest otherwise. It's an entire different battle which will have to be won first.
Possbily try a new User Profile and have the IT set up a temporary User Group, something like CAD ADMIN with higher prividges as well.
