Hello All,
I am new to iLogic and trying to access the "Application Options" under the "Tools" tab. I am trying to grab some information from a couple of fields but it seems that I don't have the right coding or Snippets that indicate how I would do so.
Please point me in the right direction of a helpful source or if anybody knows how to code this.
Thanks in Advance
Mitch
Solved by Curtis_Waguespack. Go to Solution.
Hi mhatfield,
Here is a quick example of an iLogic rule that works with Application Options. If you look up SketchOptions or GeneralOptions, etc in the API reference, you'll find a listing of all of the properties available. Or reply back with the specific properties you're wanting to change.
I hope this helps.
Curtis
'get Application Options > General Tab > User Name myName = ThisApplication.GeneralOptions.UserName MessageBox.Show(myName, "Title") 'set Application Options > General Tab > 3D Indicatior if ThisApplication.GeneralOptions.Show3DIndicator = True Then ThisApplication.GeneralOptions.Show3DIndicator = False Else if ThisApplication.GeneralOptions.Show3DIndicator = False Then ThisApplication.GeneralOptions.Show3DIndicator = True Else End if 'get current Application Options > General Tab > Select Other Delay myDelay = ThisApplication.GeneralOptions.SelectOtherDelay 'set Application Options > General Tab > Select Other Delay myDelay = InputBox("Enter a new Select Other Delay", "iLogic", myDelay) ThisApplication.GeneralOptions.SelectOtherDelay = myDelay 'set current Application Options > Sketch Tab > Display Grid Lines if ThisApplication.SketchOptions.DisplayGridLines = True Then ThisApplication.SketchOptions.DisplayGridLines = False Else if ThisApplication.SketchOptions.DisplayGridLines = False Then ThisApplication.SketchOptions.DisplayGridLines = True Else End if 'Update All iLogicVb.UpdateWhenDone = True 'Display the Application Options Dialog Box ThisApplication.CommandManager.ControlDefinitions.Item("AppApplicationOptionsCmd").Execute
Hi Curtis,
Thank you very much for your assistance as just seeing the "walk through" as to how the code works will definitely help me moving forward.
Is there a possibility you'd be able to help me with my other issue?
Again, Thank you for all your help
Mitch
Is it possible to change the color scheme and bacground color with ilogic roles? Does anybody knows how to code this?
Arnstein
Curtis,
I am attempting to adapt the code you supplied to change the inactive component opacity in the display options (see below), but keep getting the error "Public member 'InactivePartsDisplayOpaquePercentage' on type 'DisplayOptions' not found." I'm assuming that InactivePartsDisplayOpaquePercentage is the incorrect name for this option, however this is how it is refered to in the applicaiton opiton .xml file. I have tried other names for opaque percentage but can't seem to get it right. Can you tell me what I am doing wrong?
Travis
'get current Application Options > Options Tab > Component Opacity
myOpacity = ThisApplication.DisplayOptions.InactivePartsDisplayOpaquePercentage 'set Application Options >Options Tab > Component Opacity
myOpacity = InputBox("Enter a new Select Other Delay", "iLogic", myOpacity) ThisApplication.DisplayOptions.InactivePartsDisplayOpaquePercentage = myOpacity 'Update AlliLogic
Hi irvinet1264,
I think this is what you're after, or at least should point you in the right direction. If you look up ShadedDisplayOptions in the API help, you'll find all of the properties for the ShadedDisplayOptions Interface.
Dim oShadeOptions As ShadedDisplayOptions oShadeOptions = ThisApplication.DisplayOptions.ShadedDisplayOptions 'get current Application Options > Display Tab > Shaded Display Options Dim myOpacity As Long myOpacity = oShadeOptions.ShadeOpacityForEnabledComponents ‘ensure this option is selected oShadeOptions.ShadedEnabledComponents = True 'set Application Options > Display Tab > Shaded Display Options myOpacity = InputBox("Enter a new shaded display percentage", "iLogic", myOpacity) oShadeOptions.ShadeOpacityForEnabledComponents = myOpacity 'Display the Application Options Dialog Box ThisApplication.CommandManager.ControlDefinitions.Item("AppApplicationOptionsCmd").Execute
How to access the API Help files (just in case it helps someone):
I hope this helps.
Curtis
