Hi!.
I have big problem, I want export ASD model to Inventor.
Today I do it like this:
1/ save ASD model as ACIS solid
2/ I open ACIS.dwg file in ACAD Mechanical and I export this model to STEP file
3/ In Inventor open STEP file or I Import ACIS file
But this method has many many problems because When I generate 2d documentation in Inventor, I must wait long time!! Model is very "haevy". For example for 10 000 parts I have to wait sometimes 30 minutes, sometimes 2 hr for one view.
I tried all expotr and conversion methods.(acis, dwx, step, iges) used Inventor, mechnical, fusion....!!!
Do you know other methods export asd to inventor, which it is easy and faster .....
Best regards
Simon
I'm sorry for my eanglish
Simon,
Sorry, but may I ask what is ASD? Also could you post a sample ACIS .sat file from ASD? Knowing what type of model we're starting with might help us come up with some suggestions.
Thank you.
Who knows why Autocad exports 885 objects only instead 2894 and what does "Duplicate definition of block" mean? save ASD model as ACIS solid command
Command: _RBCS_exportmodel
Select elements: Specify opposite corner: 2894 found
Select elements:
Save as simplified solids [Yes/No] <No>:N
Duplicate definition of block _Oblique ignored.
885 of 885 objects exported.
