Inventor General
Active Member
Message 1 of 3 (75 Views)
API - How do you use the ConvertTo... methods of the AssemblyConstraint Object?
75 Views, 2 Replies
06-21-2013 07:13 AM
I'm trying to flip a part by converting its constraint object type from Mate to Flush.  Seems simple enough but I can't figure out the requirements of the ConvertToMateConstraint method.
Could anyone explain its use or point me towards an example?
mrattray
Message 2 of 3 (68 Views)
Re: API - How do you use the ConvertTo... methods of the AssemblyConstraint Obje
06-21-2013 07:33 AM in reply to: jacofiero
Are you familiar with the object browser? It looks like the requirements of the ConvertToFlushConstraint are thus:
ConvertToFlushConstraint(EntityOne As Object, EntityTwo As Object, Offset, [BiasPointOne], [BiasPointTwo])
It looks like you can get all the information you need from the AssemblyConstraint class,which you'll need anyways to execute ConvertToFlushConstraint against.
I hope that helps, if not can you be more specific about the problem you're having?
Mike (not Matt) Rattray
Active Member
Message 3 of 3 (60 Views)
06-21-2013 08:25 AM in reply to: mrattray
Yes, sorry for not providing a code example to begin with.
Here's the non-working code in VBA...
Public Sub FlipCon()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = oDoc.ComponentDefinition
Dim oAsmCons As AssemblyConstraints
Set oAsmCons = oAsmCompDef.Constraints
Dim oCon As AssemblyConstraint
Dim oFace1 As Face
Dim oFace2 As Face
For Each oCon In oAsmCons
  Set oFace1 = oCon.EntityOne
  Set oFace2 = oCon.EntityTwo
  If oCon.Type = kMateConstraintObject Then
    oCon.ConvertToFlushConstraint(oFace1, oFace2, 0)
  ElseIf oCon.Type = kFlushConstraintObject Then
    oCon.ConvertToMateConstraint(oFace1, oFace2, 0)
  End If
Next
End Sub
I skipped the bias points as they're listed as option.  I'm assuming I'm not using the correct object type for EntityOne/EntityTwo, but if they're not the same type as was already used in the constraint then what else would they be?
I tried simply oCon.ConvertToMateConstraint(oCon.EntityOne, oCon.EntityTwo, 0) , but failed similarly.
Does Offset require a numerical Parameter object or something...?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
