How to add Alum 6063 T6 to autodesk material library?
Solved by JavaLodge. Go to Solution.
Solved by mcgyvr. Go to Solution.
Google.."add materials to autodesk inventor"
TONS of tutorials/youtube videos,etc...
If you enjoy the "British/English" accent..
http://www.youtube.com/watch?v=eDPMx3QKi90
Or some other accent..
http://www.youtube.com/watch?v=Zjl58_BKGew
Start with one of the existing Aluminum materials by clicking the edit pencil.
Give it a name.
Enter the desired material properties.
JD - Thanks again. I am trying to add the information from the matweb.
I added all the information except the 2 circled. In the following table, its confusing because both header state "Tensile". I want to choose the ones for 72deg F value, but which one goes where?
I was able to fill out all the fields except the 2 circled ones.
The table on the matweb for 6063 T6 is confusing. Both headers show "Tensile". I need to choose the value by th temp 70ish deg F. But which one goes where (below the circled strenghth feilds)
Thanks a lot for your help Java.
While we are on the topic, When creating new material for 6063T6, I am considering not to alter the values for :
Does anyone know where to obtain this for the 6063T6 & when would it be useful to modify them?
