Inventor General
Active Contributor
TobiasZetterberg2067
Message 1 of 11 (420 Views)
AIP 2014 place and ground bug?
420 Views, 10 Replies
06-27-2013 03:47 AM
Hello!
I am trying to change the default setting "Application options/Assembly/place and ground first component at origin" to be checked and it works fine for that session, but every time I start up AIP 2014 again the box is unchecked.
Anyone else experiencing the same thing?
/Br T
pball
Message 2 of 11 (411 Views)
Re: AIP 2014 place and ground bug?
06-27-2013 04:08 AM in reply to: TobiasZetterberg2067
It may not apply to your issue, but I've noticed in many versions of Inventor if you have more than one open at the same time most settings don't seem to save.
Active Contributor
Message 3 of 11 (398 Views)
06-27-2013 05:07 AM in reply to: pball
Hi!
Do you mean more than one file or application open?
/Br T
pball
Message 4 of 11 (377 Views)
06-27-2013 09:21 AM in reply to: TobiasZetterberg2067
More than one inventor.
*Expert Elite*
blair
Message 5 of 11 (360 Views)
06-27-2013 12:01 PM in reply to: TobiasZetterberg2067
Inventor writes setting changes to the Windows Registry upon proper exit and shut-down of the software. If you have muliple instances of IV running, the last one to properly close will update the Registry with it's settings.
You may want to check the Windows Taskmanager to see if there are any other instances of IV running as well.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Contributor
Message 6 of 11 (339 Views)
06-28-2013 12:04 AM in reply to: TobiasZetterberg2067
I never run more than one instance of Inventor and I have not had any problems with crashes recently so the exits of the program has been correct after changing the setting.
I also checked the task manager and I only have one Inventor-process running.
/Br T
Member
sparrow169
Message 7 of 11 (323 Views)
06-28-2013 09:08 AM in reply to: TobiasZetterberg2067
I have noticed this issue as well. For me, it seems to happen completely at random, and I make sure to shut down and restart inventor every time I reset that setting.
andymeek1621
Message 8 of 11 (265 Views)
07-24-2013 05:16 AM in reply to: TobiasZetterberg2067
We also experience this issue. It is Random and not everytime that Inventor is launched.
Also have the odd occurance where materials libraries etc are not present and have to open and close Inventor a few times to get this working again.
Just installed update 2 (not mentioned in this) - look forward to update 3 or SP1
*Expert Elite*
mrattray
Message 9 of 11 (261 Views)
07-24-2013 05:45 AM in reply to: TobiasZetterberg2067
I assume this is a fresh install of Inventor. Did you have a previous version (or current) of Inventor working properly on this machine?
I would suspect your Windows user settings. Are you a power user or local admin on your machine?
Does IT have any sort of re-imaging software set up? When I was in college we used to have to redo our setting dialog every time we logged in because the IT department had some software that reset the registry every time.
Mike (not Matt) Rattray
Member
sparrow169
Message 10 of 11 (258 Views)
07-24-2013 05:53 AM in reply to: mrattray
In my case, it is a fresh install of Inventor, but I have had both Inventor Pro 2013 and Inventor Pro 2012 working properly on this same machine.
I am an admin on my own computer. As far as I know, IT doesn't have any re-imaging software. All my other inventor settings stay where I set them, but this one changes itself at random, usually without me ever logging out.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
