Inventor Forum
AGP (PCI mode)
16 REPLIES 16
Message 1 of 17
558 Views, 16 Replies
AGP (PCI mode)
Well, I just got my PNY Quadro4 750XGL, and loaded the NVIDIA 41.03
drivers. when I check the display properties on the Quadr0 4 750XGL tab
it says "Adapter Information - Bus: AGP (PCI mode)"
The AGP mode in BIOS is set to 4X.
The diagnostics I got in IV 5.3 follows.
So what do I need to do to get it to be in AGP mode?
WIN2K SP2, MSI KT3 Ultra MB, AMD 1800+
NVIDIA Corporation\Quadro4 750 XGL/PCI/SSE/3DNOW!\1.4.0
GL_ARB_depth_texture GL_ARB_imaging GL_ARB_multisample
GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_shadow
GL_ARB_texture_border_clamp GL_ARB_texture_compression
GL_ARB_texture_cube_map GL_ARB_texture_env_add
GL_ARB_texture_env_combine GL_ARB_texture_env_dot3
GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix
GL_ARB_vertex_program GL_ARB_window_pos GL_S3_s3tc GL_EXT_abgr
GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord
GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture
GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color
GL_EXT_separate_specular_color GL_EXT_shadow_funcs
GL_EXT_shared_texture_palette GL_EXT_stencil_wrap GL_EXT_texture3D
GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp GL_EXT_texture_env_add
GL_EXT_texture_env_combine GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod
GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array
GL_EXT_vertex_weighting GL_HP_occlusion_test
GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square
GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence
GL_NV_fog_distance GL_NV_light_max_exponent
GL_NV_multisample_filter_hint GL_NV_occlusion_query
GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite
GL_NV_register_combiners GL_NV_register_combiners2
GL_NV_texgen_reflection GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_texture_shader
GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range
GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1
GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_lod
GL_SGIX_depth_texture GL_SGIX_shadow GL_WIN_swap_hint WGL_EXT_swap_control
Workarounds = 0x60000
Workarounds2 = 0x0
SwapType = 2
Pixel Format = 18
Bits per pixel: Color 32, Depth 24, Stencil 8
GL_MAX_VIEWPORT_DIMS = 4096 x 4096
GL_MAX_TEXTURE_SIZE = 4096
Driver Rating: Unknown
HW Library Version = Win2K - $Revision: #159 $
HW Library Date = $DateTime: 2001/12/10 17:35:35 $
Optimization Level = 3
Options = 0
Warning Options = 12
registry levels:
0 path: Hardware Library
test type: GLVendor
tried: NVIDIA Corporation
used: NVIDIA Corporation
1 path: Hardware Library\NVIDIA Corporation
test type: Leaf
tried: Quadro4 750 XGL/PCI/SSE/3DNOW!
used:
setting list is for (optimized, conservative, veryConservative)
SwapType: (2 , 3 , 3 )
Workarounds: (60000 , 1 , 1 )
Workarounds2: (0 , 0 , 0 )
Text Options: (0 , 0 , 0 )
OpenGL Version: (11 , 11 , 10 )
Recommended Optimization Level: 2
UseOverlay: 0
Overlay Available: 0
Pixel Format: -1
Priority Offset Ortho: 0.000000
Priority Offset Perspective: 0.000000
Font Precision: 32.001000
Device Independent Workarounds: 0
Ideal Font Height: 2048
Max Texture Size: -1
Slice Plane Offset: 0.100000
Stroke Font List:
Driver Rating: 0
Inventor Version Tested:
Driver Version Unique: 1
Prefer Other Driver: 0
My Name:
Using OpenGL 1.1
swap behavior: swapCopy(1 or 2)
OpenGL errors: None.
16 REPLIES 16
Message 2 of 17
aaron,
    I think that's just irq mapping.
Look in the advanced > "Your Adapter Name" Tab and see what it says
there.
darvin
Message 3 of 17
I RMB on the desktop, chose "Properties", "Settings" tab, "Advanced"
button, "Adaptor" tab, "Properties" button, General Tab:
NVIDIA Geforce4 Ti4400
Device type: Display Adaptors
Manufacturer: NVIDIA
Aaron
darvinv wrote:
> aaron,
> I think that's just irq mapping. Look in the advanced > "Your
> Adapter Name" Tab and see what it says there.
> darvin
Message 4 of 17
aaron,
    you should have a tab named
"Quadro 4 750 xgl" in addition to the generic windows "Adapter" tab. If not,
then your driver install would appear to be bad. The "named card" tab is the one
with additional opengl settings on it. You may need to back up a few driver
versions.
    Have you installed the old R5.3
registry patches?
darvin
Message 5 of 17
I'm floundering here, but does that happen when a chipset update / patch is
needed (VIA chipset)?
Jeff
"darvinv" wrote in message
news:2CEC565A1E2BD7B8BEB4C2926D61F104@in.WebX.maYIadrTaRb...
aaron,
you should have a tab named "Quadro 4 750 xgl" in addition to the generic
windows "Adapter" tab. If not, then your driver install would appear to be
bad. The "named card" tab is the one with additional opengl settings on it.
You may need to back up a few driver versions.
Have you installed the old R5.3 registry patches?
darvin
Message 6 of 17
Yes!!! But I think we went through that last
week.
darvin
Message 7 of 17
Additionally,
1)    Did you un-install old driver
(add/remove programs)?
2)    Reboot to standard
vga
3)    Cancel Found New Hardware
Wiz?
4)    Shutdown > Replace the
card
5)    Start Machine
6)    Cancel Found New Hardware
Wiz?
7)    Then run the nvidia self
installer
8)    Reboot and clean up the
Desktop
darvin
Message 8 of 17
I do have the "Quadro 4 750 XGL" tab
That's where it says:
Adaptor Information -
Bus: AGP(PCI Mode)
Aaron
darvinv wrote:
> aaron,
> generic windows "Adapter" tab. If not, then your driver install would
> appear to be bad. The "named card" tab is the one with additional opengl
> settings on it. You may need to back up a few driver versions.
> darvin
Message 9 of 17
Yes, did all that. The driver is loaded. I have a quadro 4 750 xgl tab.
INV sees the quadro 4 750 xgl, but sees it in PCI.
Aaron
darvinv wrote:
> Additionally,
> 1) Did you un-install old driver (add/remove programs)?
> 2) Reboot to standard vga
> 3) Cancel Found New Hardware Wiz?
> 4) Shutdown > Replace the card
> 5) Start Machine
> 6) Cancel Found New Hardware Wiz?
> 7) Then run the nvidia self installer
> 8) Reboot and clean up the Desktop
> darvin
Message 10 of 17
Then you need the chipset patch.
darvin
Message 11 of 17
well, the Mother board is only 2 months old. I would think it could
handle a 4X AGP. So is the chipset patch the same as the BIOS upgrade
patch? How do I tell what BIOS version I have? Once I download the BIOS
upgrade patch, what is the step by step process for installing it?
Aaron
> darvin
Message 12 of 17
aaron,
    If required (maybe - maybe not),
it should be on a driver cd that came with the computer. It's usually called
"Chipset Drivers". It is actually an "os patch", not bios, and newer mobos more
often need them than not. If that is not it then I'm stumped! (:-(
darvin
Message 13 of 17
I am having the same problem. I have a geforce 2 GTS strapped into a quadro
2 pro. I am using driver 41.03. I updated my chipset drivers - no change.
I checked the BIOS - it is up to date, and it is set to AGP. What have I
missed?
Cory McConnell
BJ Pipeline Inspection
Message 14 of 17
Cory,
I'm not sure, but I think it's a function of the strapping. I think
that's when my whole trouble started. originally I was using an earlier
driver, that was tweaked the old way(no NVstrap), for my Geforce 2 to
appear as a Quadro 2 Pro. I think I was getting full AGP. But when I
upgraded the driver and Nvstraped, I got PCI mode. I think the Nvstrap
overrides and corrupts the VIA chipset driver. I may be wrong.
So, the question is, is there anyone else out there with VIA chipset and
a Nvstrapped set up that has full AGP goig?
Aaron
> missed?
> Cory McConnell
Message 15 of 17
    Besides the add/remove programs
area, take a look at add/remove hardware, and see if the nvstrap shows up
somewhere in there, as a video device extension. I've seen some os patches show
up there. Program liscense shemes sometimes register that way.
    Removing a hardware inf such as
that could hose your chipset inf's.
darvin
Message 16 of 17
On my home machine I have a geforce 2MX strapped, and it is showing it is
using AGP. I haven't updated the bios or the chipset drivers for a long
time. I don't think I have VIA here or at work.
Cory McConnell
Message 17 of 17
Nothing here. I have been all over Google Groups and can't find a solution.
Cory McConnell
BJ pipeline Inspection
news:9443A4941341F589267AA9676CE3B340@in.WebX.maYIadrTaRb...
> Besides the add/remove programs area, take a look at add/remove
hardware, and see if the nvstrap shows up somewhere in there, as a video
device extension. I've seen some os patches show up there. Program liscense
> Removing a hardware inf such as that could hose your chipset inf's.
> darvin
