In the attached file, there are many other parts around but I just took the necessary ones, I hope it is not silly and enough.
Normally the lower gear rotates continuously and the upper gear doesn't move. There is a shaped cam which pushes the upper gear upwards when necessary. What I need is to rotate upper and lower gear simultaneously when tapered surface of the "ring" sits on tapered hollow of the lower gear as the cam pushes it up. I think I need something conditional ( if there is any in Inventor) which exceeds my level.
Thanks for any help
In order for anyone to view the assembly, we will need to see the other files.
No "Conditional" like you are talking about. This will have to be done in the Simulation environment.
Kirk
