Inventor Forum
A few questions
6 REPLIES 6
Buhtwhai
484 Views, 6 Replies
A few questions
I use inventor to draw cars for competitions. They are made from 2x2x12 balsa wood blocks.
Is there a way to center the drawing directly in the middle of the page?
What type of file would i need to model the car in in order to have it cut out using a cnc router/five axis mill? Would it be the same for wheels (made out of 2mm plastic)?
6 REPLIES 6
JDMather
in reply to: Buhtwhai
I don't understand the "middle of the page" - just eyeball it!
Depends on your CAM software.  What filetypes does your CAM software accept?
Most will accept dxf if not ipt or stp.
File>Save Copy As type.....
Buhtwhai
in reply to: JDMather
For the competition they require it to be centered and our motto is
attention to detail so...... Yeah. What is can software? Also, how do I
print the drawing so that it is 1:1 scale with the dimensions?
JDMather
It sounds like you have not yet created a 2D drawing (*.idw or *.dwg) of the 3D model.
File>New and select appropriate *.idw template.
I recommend that you go through the Tutorials.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
CAM software (Computer Aided Manufacturing) creates machine toolpaths CNC-Computer Numerical Control (otherwise known as g-code) from your solid geometry.
http://cam.autodesk.com/inventorhsmexpress.php
Buhtwhai
I have not yet made a 3D model of it, but I have made a 2d drawing
blair
Inventor uses 3D models to create 2D drawings. You should spend time reading the links posted by JD
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
JDMather
@Buhtwhai wrote:
...I have made a 2d drawing
Attach your 2d "drawing" file here.
